Old 06-14-2013, 05:13 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Re: Conveyer Build
Sounds like you are a bit tighter than I am at this point. I plan on trying a bit tighter as I add the support rollers.
Thanks for the info.
Jim
Old 06-15-2013, 01:04 PM
Jared Jared is offline
One trick to improve tracking is to make the end rollers slightly crowned or fatter in the middle. That's how the old belt-driven farm equipment and line shaft equipment in old machine shops were made, if you've ever wondered how the belts don't fall off. A friend of mine was building some conveyors that had about rollers about 10" by 2" and the belts wouldn't track. I put them in the lathe and tapered the outer third of either end by about .050" or so and solved the problem.
Old 06-15-2013, 01:38 PM
Rvjimd's Avatar
Jared,
I want to make sure I understand correctly.
The center of the roller diameter is larger than the ends?
I tried the other way making one a bit concave in the center but it made it worse.
(I guess fatter in the middle makes sense. Not what I tried first.)
Jim
