Old 06-16-2013, 12:10 AM
Default Re: Conveyer Build
If you want slower speed, then use a lower voltage battery... but I'd say your speed is about right in that video. You'd want the belt moving fast to keep minimum weight on the belt at any time, takes less torque to move a lot of material quickly.
Old 06-19-2013, 03:36 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Side rollers?
Joe,
Have you got anything done on side rollers yet? I'm having trouble figuring out how to mount them to the side rails. I'm trying to do a set of rollers down each side angled toward the middle, but just don't have a good idea on mounting them to the frame. Got some brass tubes glued to the sides and was trying to use a simple wood roller and soft wire, but not having much luck yet.
Jim
