Old 06-25-2013, 07:25 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Re: Barge Unloading Facility Build
Ya, I'm sort of leaning toward some form of gantry crane. I think I'll keep it stationary and the trolley will go out over the barge and back to the conveyor or stock pile. And, the clam grab will go up and down.
I wish I could draw better, I would love to show some sketches and get more feedback. It would also be nice to see some of it on paper first before I start building.
Jim
Old 06-26-2013, 10:13 AM
Rvjimd's Avatar
Just two pictures of the start of the barge winch system. This will be the winch mounted on the dock. I plan to string a cable (string) continuous around the drum to a pulley at each end of the dock. I plan to install 2-4 shackles on the barge side of the line that can be hooked to the barges easily. This particular drum is made using two parts of brass tube and two fender washers.
Going to hook this one up using two push button switches and use a couple nimh or nicad cells to run it.
I'm hoping I can install a spring so e where on the line and friction on the drum with about one wrap, have to see if that works out.
Jim
Old 06-26-2013, 11:36 AM
Rvjimd's Avatar
Default Wiring Help Please...
Man my brain has stopped working...
Here is about the fifth drawing I have made but none of them look like they will work. In this one, I think the battery will short out when a push button is pressed.
The switches are norm open. There should be a way to do this with two push button switches correct?
I want the servo to turn CW or CCW depending on which button is pushed.
Jim
