Old 06-27-2013, 02:44 AM
Default Re: odd schoolbus
hi
to make it easier to paint. and to make it a little more durable. I've added alu sheets to the outside. now it's glued in place. more detail will be added to the side's first I want to cover the cab in 0.5mm alu sheet. the nose will be covered with 0.5mm plastic. the fenders I don't know jet. alu of plastic.
and it's not visable in these picture's but the wheelwell is moved 3mm back
it also had a little testrun. is worked fine. a bit noisy. but with some grease it will be taken care of.
