Old 07-02-2013, 05:13 PM
kolpen kolpen is offline
kolpen is on a distinguished road
Default Re: Kverneland RB 100 - 1/16
Hello everybody
Time flies and I have a made a little progress on my 7 furrow reversible plow.
As you can see I am alomost there. I mounted all the beam supports to make it variable between 19 and 31mm or 30-50cm or 12-20" in real life -and it works
Its manually adjustable via a spindle just like the first-furrow adjustment.
Then I made a new wheel with hub and a tire-thread pattern almost identical to real one. At least the dimensions is correct.
Then I've got all 'the same parts' cut out for me. I actually wanted this project to be 'hand made' but I thought that the project took me from somewhere around 2009 till now, and it would only take longer to do it by hand...
So I guess I have been around many aspects of designing and building in this project. By hand and by CNC, from drawings on a paper to exact measurements on the screen.
Mouldboard is from stainless steel and all the 'parts' has been laser-engraved to give a realistic view.
OK, so here is some pictures for you all:
