Old 07-05-2013, 07:38 AM
Berman's Avatar
Berman Berman is offline
Berman is on a distinguished road
Default Re: sloppy stearing in the scania
The factory plastic servo mount makes the servo flex side to side as it has both its mounting points on the top of the rails. It is common to upgrade to an alloy one, I have had to do this to my MAN as I had the same problem as you.
If you search tamiya scania man alloy servo mount on ebay you will find them.
The steering is still naturally sloppy, but with this upgrade you wont be over correcting it and it will track straight.
