Old 10-21-2010, 12:56 PM
dirtpusher9's Avatar
Moderator
Default Re: my attempt at a dozer build
Originally Posted by RCLogger View Post
Here is a photo of the chain I use Neil, the front ideler is made on the lathe, you can see at the front of the track frame there is a insert which is spring loaded so that if a rock gets in the chain it just adjusts and keeps on rolling..
Glad to see you post it ,Neil. Have you tested to see how well it pushs yet?
The setup Greg has built is what you need, it would deliver a lot more traction to the ground.
Old 10-21-2010, 02:29 PM
trucker n's Avatar
Yes it pushes ok but needs more traction joe hint hint
