Old 07-20-2013, 04:07 AM
kingbob kingbob is offline
kingbob is on a distinguished road
Default Re: optimus prime transformers
I havent got mine yet, but i think they're going to a problem to mount with his mounting method.
The chassis rails i used (from Joe) arent quite the same height as the stock ones, they're a fraction taller. I had to grind my fuel tank mounts to fit them. If the mount for the boxes is the same, they may not fit.
And, with the C clamp style he's used, they will be in the way for mounting the headache rack. They'll raise it by several mm, which will put it past the top of the roof of the sleeper.
Old 07-20-2013, 08:20 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
From some of the pics of the small tool boxes, you can take the mounting bracket off and use its 2 mounting holes to mount it directly to the frame. Even add a spacer if you wanted.
LYNN
