I pulled off a set of wheels to measure my axle. I am using aftermerket aluminum end pieces that lock the steering, but I don't believe it changes the width from stock. Width of the axle case (to where the shafts emerge) is 168mm. Width at ends of the hexes is 180mm. Width at the outside of the tires I'm using is 215mm, (and the tires are 115mm tall).
Thank you for the side and overhead views. I guess mine IS 1/12 - now I know. -Mike |
