Old 08-14-2013, 02:30 PM
pigeonfarmboy's Avatar
Default Re: PFB Tri-Axle King Hauler
Picked up this headache rack on ebay a while back. I liked the fact it lifts out of the way so I can access the battery in the sleeper.
Still hadn't fixed the rear crossmember cover up so it was time to change that:
From this:
To this:
You can see I also had to make a 2nd extended version of the electronics receptacle plate so the deans harness wouldn't hit the bottom of the headache rack.
Mounted up the gooseneck. Just need to run extensions to the receiver for aux control on the neck lock and my Izzy Bottom Dump train. Going to try to get some fenders and mounts fabbed up too.
Probably will do a body overhaul after Indy. Thinking Kenworth C500B to satisfy the beef factor I'm after
