Old 09-07-2013, 02:21 AM
Default Re: CAT 374D L
Originally Posted by thuangs View Post
Hi Ari,
Awesome and extremely detailed. I am having problem to seal the join completely...between cylinder and tube. I cannot blaze this area since hydraulic tube already attached to cylinder. High heat will burn out tube.
Kevin, you might try soldering it with normal tin, it melts at lower temperature and doesn't melt the brazing. You need a gas torch and you must get all the oil of the seam.
Got the cab painted
Old 09-07-2013, 08:57 AM
Hey guys, I just realized that the 374 is pretty much done
