Old 10-25-2010, 10:22 AM
pugs pugs is offline
Default Re: centering
I agree, use center drills to start holes on the lathe.
Also check tailstock alignment. To do this take a piece of barstock as long as you can put between the tail center and about 3/8" in the chuck jaws. First short chuck it in the chuck and center drill for the center to run in. Then chuck by the last 3/8" (so the chuck jaws, aren't forcing the piece off at an angle) then take a light skim cut all the way across the piece (you can take a cut from each end be be sure and get the exact same dial reading). Then measure each end with a mic and check for the tail end being bigger or smaller then the chuck end.
If it is not the same on both ends then you will need to adjust the tailstock and recut the test piece until it is. This adjustment depends on your lathe style as to how it is done, but I usually throw a dial indicator on the tailstock body to be able to measure and read how much I actually moved it (move about half the difference of diameters)
Jeff
Old 10-25-2010, 12:29 PM
Iron Art's Avatar
Iron Art Iron Art is offline
Iron Art is on a distinguished road
I agree to what has been said above, also good quality, sharp, drill bits are important to a good hole. If you need real accuracy, reaming will help. Fred
Old 10-25-2010, 12:31 PM
steamer's Avatar
steamer steamer is offline
A master machinist showed me this one. Just put centres in both headstock and tail stock. Bring tail stock up to headstock. If the tail stock is centered you should be able to hold a razor blade between the two points. If not, then just adjust the tail stock till it does, and your done. Now if your lathe bed is warped then that's a different fix. You'll need a precision level and shims to make it true over the entire length. Then go back to step one. Hope this helps.
