Fire and Rescue and Emergency Vehicles Here is a spot for all them important emergency vehicle builds. |
You know, I believe you're correct! Thanks for pointing that out to me.
No problem!
I saw this in your build photos. It looks like there is a brass bushing inside the tire, that is glued in? I looked at the axle you recommended, but need to know the size of the nut to put on the first tire and the next for the outer. also, I am waiting for a response as to size of the pin.
Yes, there is a brass sleeve glued into the plastic wheel to provide a hard/solid surface for the axle to sit in.
Can you provide me with any information on the fasteners you used?
i used metric screws, tamiya semi truck hardware, modified tamiya high lift springs, aluminum U channel, aluminum angle stock.
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
