Old 10-04-2013, 01:57 PM
Stuart's Avatar
Stuart Stuart is offline
Stuart is on a distinguished road
Default Re: New Transmission required Wedico 740 Dumper
How about a Dewalt cordless drill motor and gearbox?
I have no idea what space is available in your 740 though
Cheers
Stu
Old 10-04-2013, 02:29 PM
Cheers
Stu
I was thinking along those lines too. You can buy a cheap brand new 12-18 volt drill for around $40 here(sometimes less). I use them in my Euclid(single speed) and Kenworth(2 speed) and they work very well. I doubt you could stall either one without breaking something else. There may not be enough room though I guess. The price is certainly right!
Old 10-05-2013, 03:54 AM
titandigs's Avatar
titandigs titandigs is offline
Aussie Fabricator
titandigs is on a distinguished road
Cheers
Stu
Thanks Stu,
I wonder if anyone has a couple of pictures of one of these drills striped down.
I had a look in the local hardware shop today and for about $50 I can get one but not sure how far to take it apart.
Paul
Old 10-05-2013, 09:45 AM
Here's a picture of an 18v drill stripped down. I don't remember if this was a Campbell Hausfeld or a Black and Decker. It is the largest one I have seen so far. The motor on this one is quite long and is much bigger than a 550. The single speed that I used in my Euc is probably 1.5 inches shorter and the one in my KW is somewhere in between. I changed the motor on the single speed because it was only a 540 and spun quite fast. The pinions are pressed on making motor swaps easy if you aren't happy with the speed or torque. Hope this helps.
Reg
