Old 10-06-2013, 09:13 PM
Default Re: Steel axles?
Sorry to hear about the problem. 0.06mm is less than 0.003" so have you considered turning them down to fit? Depending on length and whether you have to reduce the full length or just the bearing areas, if you don't have a lathe, you could use a drill and a file to touch the areas to fit the bearings.
