Old 08-13-2010, 04:40 PM
Tamiya Cowboy's Avatar
Default
Next the pivot point was made out of left over chunks of box trailer rails. And then mounted to the main plate with the king pin in it.
Then I traced out and drilled bent and mounted the upright and also mounted the winch that will lift the boom.
Paul W. "Tamiya Cowboy"
Default
Old 08-13-2010, 04:41 PM
Default
Ok I got the draw bar built tonight as close as I could to the picks on there web sight. I built it out of 2 pieces of square brass tubing one slid inside of each other and then a piece of square key stock slid inside of the brass. Then I soldered 2 brass tabs on it. 4 chains 3 links long hook it to the tow arm and the rest you can see in the picks.
And here is the different ways they show on there sight to sling a rig.
Axle sling
Old 08-13-2010, 04:42 PM
Default
Front Axle Sling
The Frame Hitch
Old 08-13-2010, 04:43 PM
Default
Looks better on the Fruitliner
[/b]
Old 08-14-2010, 11:16 PM
Default
That is a good alternative to building a full blown towtruck.
