Old 10-21-2013, 06:56 AM
Rckcrwlr's Avatar
Rckcrwlr Rckcrwlr is offline
Rckcrwlr is on a distinguished road
Default Re: Rckcrwlr's KingWorth
Shot the body with some primer to I can see the parts that need another coat...
Here's the roof after a sanding
Fenders are not bad...well the right wasn't...left needs some help
Put a thin skim on and should be all I will need...I hope
Old 10-21-2013, 06:57 AM
Rckcrwlr's Avatar
I'm getting really excited for this one and the way it is turning out...
I shot it with primer again to look for imperfections...
Started with 220 grit paper
Went down to 600 grit and then used a tack cloth to remove all the dust
Old 10-21-2013, 06:58 AM
Rckcrwlr's Avatar
Laid down some primer and it's looking good...
Will let it go and then hit the whole body with 1000 grit then the final coat of FINE Primer...
Old 10-21-2013, 07:00 AM
Rckcrwlr's Avatar
Will try to hit it with 1000 grit tonight but had to do a mock up....
When will those parts get here... :dunno:
Old 10-21-2013, 07:01 AM
Rckcrwlr's Avatar
Running behind a day cab yesterday and it clicked that I needed molding around the rear window.
Dug through my styrene stock and found 2mm quarter round...
The key is to go slow and use plastic weld to attach as you go.
I've tried to preform it but it is more of a pain. Get your starting point...glue it, wait for it to dry and then attack your bends...
If you bend slow and use your fingers to warm it up, it works perfect
The patience pays off
Hoping to lay down some color today...
Old 10-21-2013, 07:02 AM
Rckcrwlr's Avatar
I opted for a flat grey base....
Then picked up some Ford Purple...
Gave the paint a warm bath
Then started laying down some light coats
How does she look??
Not sure if I want to clear the whole thing in Matte or keep the different one's. What do you think?
Old 10-21-2013, 07:04 AM
Rckcrwlr's Avatar
To make it a Kenworth...you need the grill..
Enter stage left, RC4WD Smokey Billet Semi Grill
Hit the buffer on it to get the verticals to shine a little more..
