Laid down some primer and it's looking good...
![]() ![]() ![]() ![]() Will let it go and then hit the whole body with 1000 grit then the final coat of FINE Primer...
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Will try to hit it with 1000 grit tonight but had to do a mock up....
When will those parts get here... :dunno: ![]() ![]()
Running behind a day cab yesterday and it clicked that I needed molding around the rear window.
Dug through my styrene stock and found 2mm quarter round... The key is to go slow and use plastic weld to attach as you go. I've tried to preform it but it is more of a pain. Get your starting point...glue it, wait for it to dry and then attack your bends... If you bend slow and use your fingers to warm it up, it works perfect ![]() ![]() The patience pays off ![]() ![]() Hoping to lay down some color today...
I opted for a flat grey base....
![]() Then picked up some Ford Purple... ![]() Gave the paint a warm bath ![]() Then started laying down some light coats ![]() How does she look?? ![]() ![]() Not sure if I want to clear the whole thing in Matte or keep the different one's. What do you think?
To make it a Kenworth...you need the grill..
Enter stage left, RC4WD Smokey Billet Semi Grill Hit the buffer on it to get the verticals to shine a little more.. ![]() ![]()
is that the 3m putty if so I hope it doesn't break out on you that stuff doesn't like Styrene I have to completely redo my W900A hood because its blowing out and cracking around the edges.
