Old 10-28-2010, 01:04 AM
rc_farmer's Avatar
Master Builder
Default Re: Manufacture Hydraulic Pump?
Originally Posted by FreddyGearDrive View Post
Richard,those pumps are ok if,your going to use on a dump or something that doesn't require the pump to run over a minute.I purchase a couple of them,& cooked one in a matter of minutes. If you read the spec sheet that comes with the pump.It tells you to only run in short spurts. One of them I modded to use a different motor,now it's perfect. Your still way ahead useing just the pump & changing the motor,vs $300 0r more.
It's all in what you want it to do.
I sure hope UMS does a better job gittin them to you,than they did w/me!
FGD
FGD, I am about to purchase a couple of them, what motor did you upgrade them too? Just talked to them and they are in stock.
Thanks
Giving up is not an option!!!
Rob
