Old 11-13-2013, 10:11 AM
Tinbender's Avatar
Tinbender Tinbender is offline
Tinbender is on a distinguished road
Default Re: Building a trainer
I have yet another question for the guru's.
I was trying to set the stops on my radio last night and got that accomplished quite well. But when I turned on the truck to make sure of the shifting and steering, I got a buzz sound coming from the motor. I can feel it in the tranny but there is nothing but gears in there so it has to be coming from the motor. The last time I turned it on I did not have this noise but now I do. Any suggestions?
Old 11-13-2013, 11:19 AM
rsd53 rsd53 is offline
rsd53 is on a distinguished road
If you adjusted the stops on the shifting servo, you might be over rotating (binding) the servo in one direction or the other. Does the noise go away, or change, if you change gears without the motor running?
Rob
