Old 11-13-2013, 05:29 PM
Tinbender's Avatar
Tinbender Tinbender is offline
Tinbender is on a distinguished road
Default Re: Building a trainer
rsd53,
No, I left it as it was. I also reset all stops back to factory setting of 100% and I still have the buzz. I bought a sound system and tried to install it and the speaker gave the same buzz so I took it off and now I have this buzz.
Moving the joy stick for the steering and the gear shift has no effect on the buzz. I am thi9nking about removing the drive shaft to see if the gear whine will quite down enough to see if the buzz is still there under throttle.
If this don't get fixed soon, I may not be able to go to the Jackson show.
Old 11-13-2013, 05:39 PM
rsd53 rsd53 is offline
rsd53 is on a distinguished road
Originally Posted by Tinbender View Post
rsd53,
Does it make any difference if you disconnect the motor?
