Old 11-15-2013, 09:39 PM
A.ash A.ash is offline
A.ash is on a distinguished road
Default Re: Bruder Delta Loader Conversion (my version)
Now I have a question for you guys. For this type of control (buckets, lift, etc) how do you set up your radio? With the spring centered sticks do you set everything up so that in the neutral position the lift is at the bottom of travel and the bucket curl is parallel to the surface? Or do you remove the springs? Or what?
Thanks
Alan
Old 11-16-2013, 05:16 PM
SmallHaul's Avatar
Nice work Alan, it is looking good.
i use the right stick for drive and the the left stick (throttle channel) is used for the lift without a spring loaded center so that you can leave the lift up or down without holding it there...and the left stick (rudder channel) is kept spring loaded..just set the trim so that the bucket is up as far as it can be at center.
Have fun.
Scott
"No load is too Small"
Old 11-16-2013, 11:07 PM
Have fun.
Thanks SmallHaul
Right now I have the left side setup for forward/backward and left/right. The right side is set up for lift and curl. For now I am going to leave it that way to see how I like it. Just have couple of more things to complete and it will be done. Have computer issues so I can't post anymore photos.
Alan
