Old 11-17-2013, 03:41 PM
Default Re: Construction Equipment Radio
Originally Posted by Trackerman View Post
Joe,
the programming is in the transmitter, the receivers are dumb and just act on the signal received. So effectively you could bind a third unit without a need to redo it all.
cheers
Paul
Sounds logical Paul, but has it been proven?
I ask b/c I lost connection with a rx before and had to replace it with a new one and the tx settings had to be all redone... reset all settings to zero & rebind, then start fresh again. A bit different scenario I know.
Old 11-17-2013, 04:00 PM
Trackerman Trackerman is offline
Trackerman is on a distinguished road
Joe,
using the DX, grab a receiver without resetting the transmitter and bind, it should behave the same as the one it replaces. The receiver doesn't have the smarts in it, only the transmitter. I have replaced receivers in my planes with no problems at all, everything works exactly the same way it did before change.
Cheers
Paul
Old 11-17-2013, 11:47 PM
apfubar apfubar is offline
I also agree with Paul, my experience has proven it.
If the tx is the same, then you shouldn't need to create a new model in the tx, just rebind and away you go...
Of course you need to connect the new rx the same way as the old one.
Cheers,
AP
