Old 11-18-2013, 01:59 PM
Stuart's Avatar
Stuart Stuart is offline
Stuart is on a distinguished road
Default Re: New Project!
Nice work Stu. Are the lifting arms pinned to the shaft, or just secured with set screws? How much power does your lifting servo have? The parts are looking good!
Thanks Nate, I machined a flat on each end of the shaft and they are set screwed in place for now, there's enough meat there to drill and pin if required.
Its a metal geared servo rated at 15Kg/cm stall @6v 13kg @4.8v
My lift arms are 60mm long and the crank is the same length as the servo arm so should stall at around 2kg if my maths is right? long time since i've done those sort of claculations!
Should be way more than I plan to use anyhow.
Stu
