Old 11-29-2013, 02:55 PM
unix unix is offline
unix is on a distinguished road
Default Re: Wheeled excavator Liebherr A934
Originally Posted by ptebbe View Post
That is a great project! I like the use of the slip ring. Very creative way to put the model together. I'm working on a similar model of a CAT M322d.
I had a few questions:
1. What do you use to lower the stabilizer legs (linear actuator, etc)?
2. Where did you get your hydraulic cylinders (or are they custom made)?
3. Did you make this from plans or CAD drawings?
5. Looks like you used a brushless motor for your pump. What is the Kv and how many volts are you running? Is the mount custom made?
6. what size brass tubing are you useing, and how did you get the barbs on the ends?
Thanks! Paul
Hi
1. linear actuator with Polou geared motor - custom made by me
2. custom made by me
3. yes, I draw myself in the Q-cad, and I cut on handmade cnc milling machine
5. this is Roxxy BL Outrunner 2824-26, 1380 kV, LiPo 2S (if you using 3S then kV must be 1100 - Robbe Roxxy BL Outrunner 2824-34), motor plate is custom made by me
6. tubing brass size is 12mm outer diameter and 10mm inner diameter
Best regards
unix
Old 11-29-2013, 03:44 PM
Dunga_CZE Dunga_CZE is offline
Dunga_CZE is on a distinguished road
What's the dark material you use? Teflon (PTFE)??
