RCP’s Aluminum Gravel Boxes and Accessories Welded aluminum dump boxes and more |
I have been taking this truck apart and putting it back together in order to test every box that I make so I needed to come up with a faster way to disconnect the wiring on the dump drive motor. I had a couple of small bus-bars in my junk so I hooked one up. I made a couple of quick mods to the truck side of the box pivot where it bolts to the frame and mounted the bus-bar between a brace and the rear bumper. I also drilled holes in the cross members so that I could feed the wire though them up to the cab. Now I can leave the wires hooked up to the esc and remove a short pigtail from the bus-bar to the screwdrive. Sometime in the near future I will pick up a stock set of KH rails so that I can set up a jig but for now this will help.
![]() ![]() ![]() Thanks for looking! |
