Old 12-09-2013, 12:53 PM
Stuart's Avatar
Stuart Stuart is offline
Stuart is on a distinguished road
Default Re: New Project!
Originally Posted by Ken Orme View Post
Stu;
Very good job on your engeering and maching.
I think that with 4 geared motors you will have more power than traction.
Thank you for posting your build.
Thanks Ken, yes your right the tyres loose grip before the motors stall, so thinking of adding more weight. Maybe in the wheels???
It weighs about 4kg at the mo.
You must be quite pleased seeing your hard work & great planning in motion. Well done Stu
Is the start up adjustable so it doesn't take so long? ...I like my stuff to start at the touch of a key.
Yes I love it when a plan comes together
All the sounds are adjustable on the pc, then you load them onto a micro sd card and put the card in the sound module.
It has 2 sounds for starting, a "cold start" & a "warm start" with an adjustable timer for how long to wait when stopped before reverting to the "cold start"
I must have it set for Artic conditions I need to do more tinkering with the sound files.
Looks and works nice, Stu. Great job with the lights and with fitting all the necessary electronics in such a small space. I like the front speaker placement too. What are your thoughts on the wheel motors, now that you've had a chance to run them?
Thanks Nate, I'm pleased with the speaker as well, although it does loose a lot of volume when you close the bonnet, sorry, hood
May need to cut some slots in the grill to let the sound out???
The motors are great, maybe not as smooth starting as the modelcraft ones but seem to have good power and as I said above, the tyres loose traction before the motors are anywhere near stalling. For the money and the fact they are centered, I would recommend them.
Thanks for all the compliments, still more to come
Stu
Old 12-10-2013, 06:10 PM
FlyingBeagle's Avatar
That is a great build, Thanks for the additional details on the steering. I did not realize it was a commercially available setup. I thought you were an electronics guru and built it all youself. That is a really neat product. I cant wait to see more videos of your tractor working hard.
Thanks again for sharing.
Old 12-14-2013, 09:20 AM
Stuart's Avatar
No worries & thanks for the comments, yeah the steering works really well, no fear of overloading at full lock.
I've shortened the warm start sound:
Another vid
Cheers
Stu
