Old 12-16-2013, 01:20 AM
DADSGARAGE's Avatar
Default Re: 777 HAUL TRUCK (1/12 size)
A few more pics of the truck , D11 and work bench or at least I like to call it a work bench even though there doesn't seem to be much work done on it...LOL
Old 12-16-2013, 01:57 AM
DADSGARAGE's Avatar
Progress on the frame and box.....keep in mind many things changed as I continued to build, so you may see things now in the pics that have now been changed and or removed...because I didn't like something or in most cases it just didn't work....
Old 12-16-2013, 02:20 AM
DADSGARAGE's Avatar
Building the rear axle housing and bearing holder mods
Old 12-16-2013, 02:42 AM
DADSGARAGE's Avatar
Changes made to the frame and swing arms in order to use a linear actuator as a hoist cylinder ( Firgelli linear actuator 12volt , 35 lbs , 9" stroke) This is one thing on this model that is not like the real deal....only a way of making it work, which is something I can live with as long as it works!!??
(The main frame is cut from 1/2" plate and the box frame is 1/4")
Old 12-16-2013, 03:14 AM
DADSGARAGE's Avatar
Front strut build pics ( about 1" travel ).....almost like the real deal...LOL...they will eventually get covered in so you don't see the springs and help keep dirt out.....
(cut from 3/8" plate and 1"-1018 bar stock )
Old 12-16-2013, 03:38 AM
DADSGARAGE's Avatar
More strut pics.....
