That bucket is a beast
The bucket is a float load in itself . Looking good !
Coop, if you are welding steel, have you considered aluminum bronze filler metal? I’ve been wanting to try tig brazing myself but am mostly working aluminum...
![]() Quote:
![]() And I've used heat absorbing material and heatsinks, just haven't done it enough??? ![]()
WOWZERS! Seeing the bucket puts it into perspective just how BIG that machine will be!
![]() ![]() ![]() ![]() ![]() ![]() ![]() I still have a few structural spots to weld up and clean some up but it’s together. Also the silver aluminum parts that are bolted together between the attachment braces are just there for fuxtuerimg. I cut spacers to length and have a straight rod connecting one side to other to keep things square.
Fancy
Looks great
You have some serious skills. Came out great!
The cat did all welding for him.
This things a beast!
Here's wishing you a verry happy bday, RW
Happy birthday Cooper
Happy birthday Cooper!
Neil. |
RW, hope your special day was, well, Special.
Big iron is awesome! |
Happy birthday youngster
Thank you all, I’m great full and happy to see another birthday. When I was younger I just couldn’t wait to turn another year older. Now,,,, the time flies by and before I know it ,another year has past!! Not looking forward to celebrating anymore birthdays but definitely looking forward to having many more!! Cheers and thank you all.
![]() ![]() ![]() ![]() ![]() Bucket dump, lift and articulation cylinders being made. Using steel tube (seamless) for bucket and steering cylinders. Had to use stainless tube for lift cylinders. Couldn’t get the right size I wanted in steel. Still needing to machine bottom caps and oil ports.
Everything is steel except pistons, they are aluminum.
The man is working in steel great job DB very nice work.Ed
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
