Knowing that the dozer needed more weight added to it, I undertook that task tonight. I added approximately 3/4 of a pound to it tonight. The process I undertook I call the Skeeter special. Cut lead to fit where it's going, mix epoxy, & enshrine the lead in an epoxy coat to eliminate lead exposure(s).
![]() ![]() I sure hope this will be enough weight for it, as it's getting hard to find places to sneak more lead into ![]() Last edited by skeeter; 11-24-2017 at 09:31 PM. Reason: left out pics |
The video I was trying to post earlier. I called my brother, he's the smart one with computers. When I told him the problem he started laughing hysterically. He then told me I was a dumb@ss, & inquired why I didn't just upload the video DIRECTLY yo Youtube from the phone. He thought it was super funny that I had been Emailing the vids to myself, then uploading them to Youtube from the computer. I told him that NOT EVERYONE is as computer smart as him. without further adieu, here's the vid. Like I said before, it DON'T push well, as I HAVEN'T yet installed the metal wear plate on the blade.
https://www.youtube.com/watch?v=YChiFPc-yEE The New BIGGER batteries made a HUGE difference in this thing. I forgot to time them, but I'm sure I can live with these batteries. |
Glad the real batteries finally showed up.
Looks like it pushes pretty well. Do you know anybody who reloads for shotgun, or is into muzzleloading shotguns? Lead shot can pack weird areas much easier than rod. Also once you run out of lead hiding places, think about brass plates glued to flat surfaces. -- Put away the servos, The delta loader conversions seem to all use the dual-output tamiya gearbox that use the 280-ish motors.
What do ya mean "Cars are neither Trucks or Construction"? It's still scale, and i play fairly well with others, most of the time... Last edited by frizzen; 11-25-2017 at 01:54 AM. |
I LOVE the idea for the plates. If/when I run out of room, & need to pack more, I'll be employing that method!
Unfortunately, I do not know anyone that reloads. I do, however know of an outdoors store near me, that has said re-loading supplies. Perhaps Monday I'll head there & see if I can acquire some of them lead BB's. I've got the copper BB gun type BB's but I don't think they are as dense as the lead ones are. No more Tamiya gearbox's here! I still have 3 in the parts bin. I don't like how fast they break. ![]() https://www.ebay.com/itm/DC-3-6v-Gea...72.m2749.l2649 IDK if they will fit in it, or not, or how well. Once that SLOW boat from China carrying them arrives me, I'll find out if they will work. Last edited by skeeter; 11-25-2017 at 02:54 AM. |
Today, I lost a dear friend. A friend that's been there for me through thick, AND thin. A friend like no other. We thought you were a goner before, but you pulled yourself together, & soldiered on.
![]() Today when your tails shaft disintegrated, I knew it was the end. Rest In Pieces my friend, you'll truely be missed by me! ![]() Today at 3:15Pm, while I was attempting to craft a part for the Bruder skidsteer conversion my lil buddy, the flex shaft for my immitation dremel tool had the BIG one. The shaft that goes into the colette snapped off. It was a good run of 2+years. I suppose it is time to close this chapter, & start anew with a Dremel tool, The REAL brand name one! Last edited by skeeter; 11-25-2017 at 11:34 PM. |
Alas, poor flex-shaft, taken before its time. Hopefully you new fast-tool replacement lasts longer.
Hey what kinda height, width, and length do you have on that Fire Ladder? Not counting the search light, since i'd knock that off first thing. Uh, for research purposes...
![]() Quote:
Since I have that d@m Skidsteer apart today, here's a couple pics of the custom fabricated mount I made to hold the servo that operates the boom lift. There's already a few sanps posted of it, but they are with it installed in the machine. ![]() ![]() Last edited by skeeter; 11-26-2017 at 10:06 PM. Reason: 4got to add the other pic |
![]() Quote:
I really cannot praise the Sherline machines enough for a beginner. Easy to assemble and easy to use. This was my first small mill and lathe which I still have after 25 years of use. Both have been upgraded many times and very few parts replaced. While they do seem pricey at first, they are worth every penny. Size is an issue with them thou. You can just make wheels for the semis over the saddle on the lathe without some mods but the accuracy of the machines is much more than needed for this hobby. The many available options are one of the big plus' for me.
Must add that I have 6 of the Sherline machines- 3 lathes and 3 mills!
LYNN |
I'lll have to take some measurements of the ladder, tomorrow fir ya.
HOPEFULLY Santa got the hint, & will be placing a new Dremel tool under the tree for me ![]() ![]() Last edited by skeeter; 11-26-2017 at 12:18 AM. |
Today I made a lil more progress on the Bruder Skidsteer conversion.
Now lets test things out!
Testing the programmable beacon lamp https://www.youtube.com/watch?v=8EuY1RwZ4qA Testing the boom lift https://youtu.be/toAzzow-0nc Um,....yeah, there's a problem here! I knew I SHOULD have tested that Savox servo PRIOR to installing it in the model! It glitches REALLY bad. Reminds me why I pulled it from the crawler to begin with! Well.............I guess tomorrow can be spent undoing what I did today, so I can change that servo to a different one. HOPEFULLY that one DOESN'T glitch like this one does! I think I will test it BEFORE installation ![]() |
Since our little case dozer at the house is dead, we rented a D4 to finish up a lil work. I snapped some pics of the Bruder conversion with it's 1:1 likeness. After seeing the Bruder perched upon the Cat D4, I am more sure than ever that the Bruder is modeled after the D4! You take a look at pics, & decide fir yourself.
Well...................poop! I just it ate at me WHY would I put a servo into the misc parts bin, if it wasn't any good. I just had to do something about it, so I went out tested OVER a dozen servo's with the servo tester. ALL of them glitched. EVEN the brand new hitech micro servo that I just got. I think my servo tester is boogered up! Tomorrow, I'll have to make a trip to the LHS, & see if I can acquire a new servo tester, as well as a new servo. I just want to make sure that when I return home with the new tester, IF in the event all them servo's went bad (I CAN'T imagine why they would) that I have a brand new one that I can place into the skidsteer to get 'er working...........WELL, as working as can be, until the Sabertooth 2X5 gets here to make the wheels drive.
Hi Skeeter
It all looking good congratulations on your excavator purchase. Will be looking forwards to seeing it and the skid steer in action soon.
Regards Mark Over the Pond in the UK Member of Ribble Valley Radio Controlled Truck Club my weather station To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Thank-you, sir! IDK if the excavator will be used until the weather dries things out a bit. It's too wet here now. I have rocky ground, but it got clay like properties to it, if that makes any sense.
HOPEFULLY tomorrow, or day after at the latest, the Sabertooth will be in my hot lil hand. Soon as that thing gets here, Skidsteer will be running. |
I've REALLY been wanting a CNC machine, & a lathe. I've found a lathe at Hazardous Freight (Harbor Freight) although small, it'll work for what I do, IF I can find a spot for it in the garage. ?
![]() I've found this CNC on Evilbay. Is it any good? will it work? Is it any good? Will it have longevity, or die within a couple projects? https://www.ebay.com/itm/4Axis-VFD-3...19.m1438.l2649 |
Machine would be fine for light milling in plastic only or engraving. I would not use it for much of anything other than plastic. No telling what kind of bearings are in it. Milling machines need bearings that can take a side load. Engravers and drill press' do not have bearings made for side loading. That is why a drill press will start making oval holes besides bad drill bits.
I would get a regular milling machine and convert to CNC. Need to go slow and learn process as you go. I speak from 30 years of machining experience- both manual and CNC.
LYNN |
![]() Quote:
I plan to take it slow, starting with a small machine, & eventually, HOPEFULLY get into bigger machines. |
Today, I installed the new Traxxas 2075 servo into the skidsteer conversion.
![]() ![]() ![]() The gears from the Savox DO, however fit the Traxxas 2075 servo's. ![]() ![]() Last edited by skeeter; 11-27-2017 at 07:43 PM. |
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests) | |
