Old 01-22-2013, 12:23 AM
Newcastle's Avatar
Newcastle Newcastle is offline
Newcastle is on a distinguished road
Default Re: CAT 374D L
Hi. Great build. What kind of rpm are you looking from your motors after the reduction?
Old 01-24-2013, 06:29 PM
tracksntreadslou's Avatar
Coming along Nicley Ari ..Your attention to detai is awsome ..Pretty much giving it your own signature with all the little changes ,extras and add ons ..When your milling out the smaller holes can you pretty much cut through the thinner guage material or do you have to make multi passes with those fine bits..Feed rates make a difference as well? Thanks Ari and Nice work
Old 01-26-2013, 01:39 AM
With those smaller bits I like to take several small passes with a higher feed rate.
Today I managed to make the upper cooler grill
Old 01-26-2013, 06:03 AM
Looks fantastic Ari! It won't be long now!
Old 01-26-2013, 06:33 AM
Thanks Reg, I hoping to get the hydraulics up and running in few weeks, just missing filters and the tank.
I'm anxious to see how my cylinder will hold the pressure
To be honest there's still a lot to do, and it always seems to get harder and harder towards the end.
Here's the lower grill
Old 01-28-2013, 03:13 AM
awesome job so far Ari . Question, did you order your internal gear online ? The site states they only except online payments from the UK . And of course , the 1's I need are not in stock .
Old 01-28-2013, 03:30 AM
Hofabooz's Avatar
Hofabooz Hofabooz is offline
Hi
What a great model your attention to detail is amazing, thanks for sharing with us all, looking forwards to seen this progress.
Regards
Mark
Old 01-28-2013, 07:09 AM
Yes I did. They will send you a invoice to your email and you must pay that in advance.
It's simple to do in Europe when using those IBAN and BIC numbers but I don't know if are you able to use them when paying from outside EU.
Old 01-28-2013, 08:11 AM
OK I'll try them again . worst case I cut them myself . I already have it programmed . It's just a good couple hours to cut in the mill in steel .
Old 01-30-2013, 11:52 AM
rc entreprenøren rc entreprenøren is offline
rc entreprenøren is on a distinguished road
This is the greatest build ever. This machine is going to awsome...
Old 02-10-2013, 05:18 AM
Slow progress
Old 02-10-2013, 08:28 PM
John T. John T. is offline
John T. is on a distinguished road
WOW i am sooooooo jelious. such awsome work it just blows me away wow!!!!
Old 02-17-2013, 02:39 AM
I got the hydraulic system up and running to test leaks and found one on the stick cylinder tubing I fix that and made a little video of the test run.
There's 7,2 kg weight on the bucket and it seems to have much more lifting capasity, all though it need lot of counter weight
http://youtu.be/M9QHtM6sdxI
Old 02-17-2013, 02:48 AM
D8R D8R is offline
will you manage counterweight made in alu or have to do in steel?
Good looking steps.
Guess by now that you are an expert on programing!
Dan
Old 02-17-2013, 07:52 AM
Finally its moving!
Not to bad with only one leak, looks very smooth in the hydraulics!
Old 02-17-2013, 12:24 PM
Just one leak?! ..that's pretty good on start up. The real test will be when you're working the snott out of it for a couple hours straight, maxing the pressure constantly!
Old 02-18-2013, 06:49 AM
if you need anyone in the UK to order stuff and forward it on, then let me know, don't mind helping fellow modellers out..
Elliot
Elliot.
Old 02-18-2013, 07:12 AM
Elliot
I'll keep that in mind Elliot thanks for the offer . I found a co. state side that has 1 in stock . Same price when converted .
great job so far Ari your truly an inspiration for me to get my but in gear and get 1 of mine done
Old 02-18-2013, 09:20 AM
Dan
I propably must put led inside
I would have never believe that this thing can have so much power, I was just lifting a full size car tire with steel rim which propably weighs around 20kg and it didn't even struggle.
Old 02-18-2013, 01:09 PM
That's a bit extreme, what do you have the pressure set to?
