Go Back   RC Truck and Construction > RC Truck's Kings of the Road > Australian Rigs & Roadtrains
Australian Rigs & Roadtrains A place for aussies to show off their unique truck configurations.
Old 08-09-2014, 09:02 PM
robcakes robcakes is offline
robcakes is on a distinguished road
Default Re: Freightliner Logger - Built By PaulNZ
looking good, really like how you have cut the cab , cannot wait to see more of your progress
Old 08-11-2014, 05:38 AM
PaulNZ's Avatar
PaulNZ PaulNZ is offline
PaulNZ is on a distinguished road
Hi All
a small update:
I moved the cab back 10mm with the idea of adding the 10mm to the Hood to give the clearance needed for the guards as they rotate through under the air cleaners and found that I ran into a few other problems so I weighed up which was the hardest and went with the lesser evil.....
So I lifted the cab about 3mm and also the Hood, I will fit the air cleaners in the same place but 5 - 10mm higher than std.
Made the Hood hinges from brass as per the photos below, with the J Hinge that I made, it tends to pull the Hood away from the cab and so it has now enough room to clear the air cleaners (mounted higher as mentioned).
Battery fits nice and does not push into the cab beyond the dash, this was what I was after, a nice clean interior, I like as much detail as I can get.
Next I will make a start on the cab guard, I will paint the cab this weekend and then work on the interior, RHD of course. enjoy........
Cheers
Paul
Old 08-11-2014, 05:40 AM
PaulNZ's Avatar
Old 08-17-2014, 07:21 AM
PaulNZ's Avatar
I have a new Grill and a Cab Guard ( well almost )
Old 08-17-2014, 03:18 PM
mavrick0 mavrick0 is offline
Both look awesome. If you make more of the grills I'll take on off your hands. Did you design it to bolt up like the stock one?
Old 08-18-2014, 01:37 AM
PaulNZ's Avatar
At this stage I will use thin double sided tape but you could easily drill and tap it to take the M3 screws, it is 8mm thick so would be easy to do.
Old 09-01-2014, 06:27 PM
tracksntreadslou's Avatar
Nice build Paul ..Cab guard looks awsome...how are you managing to stick the parts together ?
Old 09-06-2014, 08:01 PM
I like your cab guard - the hood pivots are nice and simple too.
Old 09-06-2014, 08:57 PM
PaulNZ's Avatar
Thanks guys
Guard is held together with a clear epoxy, a bit like jb weld. I did have a go at soldering it but it was too tight to get all the joints done clean, if you have ever done this you will know what I mean, soldering aluminium is different to brass etc, main issue was the difference in size of the material.
Update on the grill mounting, I have managed to drill and tap the back of the grill to take m3 screws in the original hood positions, the two bottom ones on each side pick up the hood hinges.
Cheers
Paul
Old 09-14-2014, 01:56 AM
PaulNZ's Avatar
Cool Re: Freightliner Logger - Built By PaulNZ
Hi All
a bit of an update:
Cab painted, not totally happy with it, must be the worst paint work I have ever done, I just could not get it to apply, it may still be too cold but its done now and its a working truck so it will do.
I am making my own sign writing on the door (paper version stuck on to test for size) and I have a pair of monster stacks that I have made myself to go on it, most of the lights are working on, I have done it so the low beam inner pair, roof lights and tail lights are always on, and when you go forward the high beam (outer pair) and the spot lights in the bumper come on. indicators work on turning and brake lights on when you use reverse as a brake but all off in neutral, all four indicators flash after no signal after about seconds. Rear cab guard still needs to be fitted, hood straps to stop it opening when you hit the brakes, air cleaners, the list goes on......................
Have purchased my trailer, this will slowly get converted to a true Jinker trailer as seen in my first post behind the KW. and of coarse I need to replace the pipes with Logs , you will see that I have already removed the mud guards an the main pole will be replaced with a square one, I choose to buy the pole trailer and convert it as it had most of the running gear I needed and it will work out cheaper than buying all the parts by them selves, plus I get to use it as I build it I will also make my own bolsters from either steel or brass so I can solder it all together as they will be painted anyway.
I still have a fair bit to do on the truck and the trailer but it was such a nice day in Sunny Qld that I thought an afternoon delivery of pipes to the local construction yard was in order, its funny, my 15 year old son was not interested during the build all that much until I started to drive it, he then took over and did most of the driving
I think I will make a bigger bumper for it as after lifting the cab and hood 3mm it needs to come up a bit, this one will be for sale if anyone is interested.
PS: being an NZ Rig under the Aussie Rigs Topic it had to be RHD
oh and just a mention the speed and power are really good with the 80T and std pinion
Old 09-14-2014, 08:38 AM
kaptain Jack's Avatar
Looking good,Paul.
Old 09-14-2014, 04:51 PM
apfubar apfubar is offline
Nice!
Old 09-14-2014, 08:17 PM
flatdeck's Avatar
flatdeck flatdeck is offline
Great looking truck Paul....
Old 09-14-2014, 08:49 PM
left hand steering kool
Steve
Old 09-16-2014, 01:16 AM
mamwr mamwr is offline
mamwr is on a distinguished road
The paint looks pretty good to me! Cool looking truck!
Old 09-16-2014, 11:09 PM
1985 kenworth's Avatar
wow paul very nice work....looks very clean and just like a truck you would see hard at work ..i like it
dwayne
Old 09-18-2014, 05:37 PM
PaulNZ's Avatar
Originally Posted by kaptain Jack View Post
Looking good,Paul.
Thanks Jack
Originally Posted by apfubar View Post
Nice!
Cheers
thanks Wayne
....???......Right hand steering, but we do drive on the left side of the road
don't look too close but thanks anyway
Thanks Dwayne, and yes it will be a working truck, once I have modified it to how I want it should look like something you see in the bush in NZ, and Canada for that matter, they both share the same way of logging big trees
Thanks all for the comments, I'm really enjoying building this truck, I think the bug may have bit!
Old 09-18-2014, 09:44 PM
BRICKNICK's Avatar
That's a real sweet freight shaker
Old 09-22-2014, 08:40 AM
PaulNZ's Avatar
Hi All
a couple of updates
Got some custom pipes made from Aluminium tube and polished them up.
They are 10mm in Dia. I did do a set of 12mm ones but they looked too big for my truck, would be ok on a show truck though.
Air cleaners on. painted them to add a little personal touch, and it hides the inlet that used to be on the front, Freightliners go through the hood from the side so this worked out great. (green is a slight different shade but looks closer than the photo shows, but saying that I might mix a new colour and do a second coat to get it closer)
Hood has a couple of straps to stop it tilting forward under brakes.
Rear cab guard mounted, need some chains and maybe work lamps
still more to do but getting close with the truck, then on to the trailer
Paul
Old 09-23-2014, 07:36 AM
flatdeck's Avatar
Looks great Paul....
