Go Back   RC Truck and Construction > RC Truck's Kings of the Road > Australian Rigs & Roadtrains
Australian Rigs & Roadtrains A place for aussies to show off their unique truck configurations.
Old 07-18-2014, 08:21 AM
PaulNZ's Avatar
PaulNZ PaulNZ is offline
PaulNZ is on a distinguished road
Default Freightliner Logger - Built By PaulNZ
Hi all
Here is the start of my first truck build.
I have been doing models and building 1/24 Scale slot cars for many years but this is my first RC vehicle of any type.
This is my inspiration: an XL Classic Freightliner which will be built in the Rotorua Forest Haulage colours and the spec of the truck will be like the KW's below.
And so the fun begins................
Cheers
Paul
Old 07-18-2014, 09:06 AM
Default Re: Freightliner Logger - Built By PaulNZ
Cool! I can't wait to see more!
Reg
Old 07-19-2014, 04:06 AM
bruce's Avatar
bruce bruce is offline
bruce is on a distinguished road
Should be a great build. Like the pic of the kenworth, same configuration as mike lambert runs out of mount maunganui. Very nice
Old 07-19-2014, 07:08 AM
Steve1503 Steve1503 is offline
Steve1503 is on a distinguished road
Have fun, but beware, one is never enough.
Old 07-19-2014, 10:58 AM
PaulNZ's Avatar
Hi, yes it was a toss up between RFH and Lambert, both are good liveries.
I know these trucks well, I used to work in NZ as a Diesel Tech in the Bush around the Bay of Plenty and lower NI.
Old 07-19-2014, 08:24 PM
Trucker_Jo's Avatar
I have always thought NZ logging was pretty cool. Nice truck choice should be a fun build
Jarrett
Old 07-19-2014, 10:56 AM
PaulNZ's Avatar
A little bit more done today........
Bearings all round as you would expect
Diff's mounted to chassis but I may remove them to make painting the chassis and axles easier
more tomorrow .............time pending
Paul
Old 07-20-2014, 04:38 AM
bruce's Avatar
Hi Paul
I did work experience out at lamberts mount work shop. I worked on some of the first T900 tri drives he built there. Always had a great fleet of trucks
Old 07-20-2014, 07:35 AM
PaulNZ's Avatar
A bit more done today but that will be it for a while...............
Diffs and Chassis with Front axle fitted ready for Rotorua Forest Haulage Green ( as I said this is my first truck build so Tri Drive will come later)
Assembled the gearbox, ran out of the "ceramic grease" that comes with the kit (little too liberal in the diffs LOL) so I used the white lithium grease that I use on my cnc machine and it is really tacky and smooth, I will now strip the diffs and fill them and see what difference it makes, I think this might just be what I need to make them tighter.
will update when I can get more done
Paul
Old 07-20-2014, 08:04 AM
flatdeck's Avatar
flatdeck flatdeck is offline
Keep the up dates coming....
Wayne
Old 07-26-2014, 05:40 AM
PaulNZ's Avatar
Update:
Painted the chassis and Diffs today, will lay another coat tomorrow as it too cold now.
the colour is the same its just the flash making the Diffs look different.
and the Gearbox, painted eaton Roadranger Blue, its a little darker than I had planned but it still looks ok.
Cheers
Paul
Old 07-26-2014, 07:28 AM
crisis time's Avatar
Looking good mate
Old 07-26-2014, 10:44 AM
flatdeck's Avatar
Will the truck be that shade of green??
Looks good
Wayne
Old 07-26-2014, 06:37 PM
PaulNZ's Avatar
Looks good
Wayne
Yes, if you scroll up the KW is the paint scheme,
Forest Green chassis and middle section of cab
Park Green lower section of cab
Pure white top section of cab
cheers for the comments
Paul
Old 07-29-2014, 12:23 AM
PaulNZ's Avatar
Update:
Had a bit of time today so put a few shiny bits on the chassis:
As you can see, the gearbox is black, but I painted it a Saturn Black same for the shocks, why would Tamiya anodise these "PINK" !!!???
Turntable will be left on, the Bolster will clip into it giving the turn and the oscillation it requires, I can also unclip it and use any other trailer making the Model a lot more versatile. I an thinking of turning the base around though to move it forward on the chassis.
Cheers
Paul
Old 07-29-2014, 04:04 AM
Very nice
Really like the green
Old 07-31-2014, 01:12 PM
Trucker_Jo's Avatar
Good color choices. I agree that you should move the 5th wheel. Your log bunk should be center(ish) over the front drive axle. You will get better weight distribution that way
Jarrett
Old 08-06-2014, 07:53 AM
PaulNZ's Avatar
Time for a bit of an update:
Got most of the chassis done, rear bumper still needs to be done in aluminium but it will look similar.
All electric's are in, light kit is in but still to do all the front lights and roof clearance lights. I am using a 12 channel car light set, its not bad, gives me all that I need really. not sure if I will get a sound system as room is of a premium.
I have managed to get all the electronics under the tilting bonnet, this will make it easy to change the battery. and it looks cool
Went for my first test drive with the 80T motor, I'm pleased with the speed, will see how the power is when I get it finished, I have a 65T on the shelf in reserve.
more soon........................
Old 08-06-2014, 11:25 AM
I'm liking the green, nice. Good job on cutting the hood also. This will be one awesome build, and can't wait to see more. May I ask where you got the electrical unit from? I'm interested.
Old 08-07-2014, 07:29 AM
PaulNZ's Avatar
Hi, thanks for the comments
I got the light kit off ebay, its just a std car one that I have modified to suit the truck.
Cutting the hood was not easy, not sure what everyone else that has done this did but I used an exacto knife and heated the blade and slowly made a cut @ 10mm at a time in two depths, 1st depth was to make a "valley" then second was to cut through, I managed to keep all the detail and get a reasonably straight cut, still have not cleaned it up when the photo was taken.
