Old 12-09-2010, 10:10 AM
Default Re: Barge-Mounted Clamshell Crane
Tagline system is very ingenious! And the bucket is so well done - did you weight the lower pulley crossbar or was it heavy enough by itself? Everything works so smoothly - a credit to you craftsmanship. Keep up the good work.
Old 12-09-2010, 10:27 AM
kerst's Avatar
kerst kerst is offline
Wow! Great project! Just up my street.
My internet connection is too slow to see the video, so i have to wait!
kerst
Old 12-09-2010, 10:29 AM
kerst's Avatar
the clamshell bucket is beautiful. I once built one for my Manitowoc. I really enjoyed that project.
how did you convert the servo motors to run the winches?
kerst
Old 12-09-2010, 06:12 PM
Jared Jared is offline
Originally Posted by lorenzo View Post
Did you calculate the force that the spring should have or just did you do it by trial and error.
Trial and error. You can see all the holes I drilled in the lever.
Thanks, td9clyde.
Originally Posted by 9W Monighan View Post
Very nice and simple. I like the tag line set up. On some of the early 1900's machines I've been around: I saw a weight that runs up and down a track on the boom this was on a Erie steam crane. My buddy has a Insley half swing machine he's starting restoration on and it has a pipe with a pully on top where a weight just slides up and down inside the pipe,but that was probably for the trip rope when it has a shovel front mounted.
Thanks. I toyed with both ways a little bit but I couldn't figure out how to make it slide smoothly without pulling too hard and without being too bulky. At this scale friction plays a bigger part than it does on bigger stuff.
Originally Posted by tc1cat View Post
NICE!!! Now you just need to scale it up to 1/16th so you can play with all of the semis We need something like this for bigger scale trucks to use instead of just the elevators and payloaders. 30" in 1/48th is about 90" in 1/16th So about a 8' boom would be fun to watch
Thanks. I've been kicking around a 1/16 scale Bucyrus Erie 22B, but that won't happen for some time yet due to a shortage in the employment department.
Thanks, Ken. I had to weight the crossbar a little bit.
kerst
Thanks, kerst. It was kind of a trip when I got it put together and not only did it look like a real clam, it acted like a real clam. On the servos, there are two ways. I couldn't find the page I used, but this is basically the way I did it, though these aren't the best instructions: http://www.instructables.com/id/How-...or-Continuous/
Or you can do it like this: http://www.seattlerobotics.org/encod...0for%20PWM.htm
I'm not really an electronics guy and I didn't feel comfortable poking around the electronic guts. But this is probably the better way to do it because you don't have to worry about the pot changing position.
Old 12-09-2010, 09:18 PM
W900snowman W900snowman is offline
W900snowman is on a distinguished road
Very impressive I love the video and thanks for posting the pictures. Everyone around here sets the bar pretty high.
Old 12-12-2010, 03:49 PM
So the purpose of the tag line is to aid in the opening of the clam bucket?
Nevermind the lack of "house detail", you've done yourself proud with the exquisite engineering of a super smooth working model.
"Function before beauty" has always been my motto.
Old 12-12-2010, 03:54 PM
lorenzo lorenzo is offline
No Joe, the function of the tag line is to reduce the uncontrolled swinging of the bucket.
Old 12-12-2010, 08:50 PM
Thanks, Lil Giants. What lorenzo said. And to keep the bucket from spinning and twisting up the hoisting lines. If you have a power operated tagline you can even pull the bucket in to dig closer or cast it farther away from the machine.
Old 12-13-2010, 01:48 AM
There are power operated taglines too? Didn't know this.
Old 12-13-2010, 09:55 AM
kerst's Avatar
I know that for example the Manitowoc 4600 has a power tagline.
http://www.manitowoccranes.com/MCG_M...nal_cranes.asp
Kerst
Old 12-13-2010, 12:08 PM
Many thx Kerst .
Old 12-13-2010, 01:05 PM
The power tagline on a clamshell is also used for the dipper trip when the machine is set up as a shovel. It usually runs off the end of one of the drum shafts and has a clutch that is set to drag a little bit to keep a constant pull. When you want to trip the dipper or pull on the clam you fully engage the clutch.
Old 05-15-2011, 03:20 AM
I haven't made any progress on the crane for a while. Last winter when I was unemployed I had piles of time and no money, and now that I have a job I have money and no time and energy. But anyway, today it was time to refill the laundry detergent box so I put the clam bucket on the job. It took about an hour and a half to get it done. I shot a little video. I have a longer one if demand is there.
http://www.youtube.com/watch?v=wdm62...eature=feedwll
Old 05-15-2011, 09:19 AM
Works very nice and smooth. One problem, How can I do that too? I use liquid detergent
How are your radio sticks set up? I sorta followed on the video.
Old 05-15-2011, 12:03 PM
You might have to build one of those bags or buckets that helicopters use to drop water on fires. Left stick is u/d for boom, l/r for swing, right stick is u/d for the holding line, l/r for the closing line. To hoist a full bucket the right stick goes to the bottom left. If it was a dragline I would have the drag drum be u/d on the left stick and boom as l/r on the right stick.
Old 05-15-2011, 08:00 PM
Your set up is similar to mine and Smallhauls set up. I have to leave my boom fixed at one angle. Scott has the throttle stick for his boom angle but it's turned on with one of the switches that I found out by accident when I boomed up into the cab I didn't see it happening because some guy was talking to me and I wasn't watching the boom.
Here's mine hope the dashes don't confuse you.I don't know how to put the diagram with out the letters bunching together.
LEFT STICK--------------------------------RIGHT STICK
--- not used-----------------------------------hoist up
swing left-----swing right------------------- drag in------drag out
------- not used ---------------------------------- hoist down
Old 05-15-2011, 09:05 PM
I should have done this before:
------LEFT STICK--------------------------------RIGHT STICK
------boom down---------------------------------hoist down
swing left-----swing right-----------------bucket close---bucket open
--------boom up------------------------------------hoist up
My hoists are set up opposite of yours because on every machine I've ever run if you want something to go up you pull back and forward to go down so that's the way I think. I never thought about locking out the boom hoist but I'd love to be able to do that. I'll have to see if my radio can do that.
Old 05-15-2011, 10:27 PM
AHH, I'm used to Bucyrus-Erie machines, they all hoist up by pushing forward on the hoist lever. I've run Bay City shovels and you pull back to hoist like most others. I heard several arguments before about why B-E does things different but can't remember why they did it. It makes sense to me because the first shovel I ever operated was a 10B B-E 3/8cy shovel.
If I ever get an operator on my 9W that likes Marion controls; I'll just reverse the hoist stick.
Old 05-15-2011, 11:19 PM
Seems like I heard the reason for that, at least on the big draglines anyways was so you could push/pull both levers in the same direction when the bucket was moving away or towards the machine. Somewhere on Youtube a dragline operator was explaining why that was but I can't remember what or whose video it was. I figured on the small machines that's just the way the control linkages worked out. I wonder if the BEs with air controls are the same way?
Old 05-16-2011, 01:57 AM
How about one of these 9W, http://www.garbro.com/g_series.htm
Later, Neil#2 aka doodlebug.
