Old 12-06-2010, 10:45 PM
Jared Jared is offline
Default Barge-Mounted Clamshell Crane
http://www.youtube.com/watch?v=0x5b3E7Mp5o
Hi, guys! Here's a video of my 1/48 scale (give or take a little) crane playing in the "sandbox". I started it with the idea it would be a quick-and-dirty build which it still is, but I've been working on it off and on for a couple years now. The machinery deck is 4x7" and the boom is about 30". I didn't really design it, I just did a quick sketch and started building and then later modifying to make things fit. I decided to build a barge-mounted crane because I have a tugboat that needs a barge to push and also so I didn't have to mess with an undercarriage. I used this and others like it as inspiration: http://www.generalconstructionco.com..._DataSheet.pdf
I don't have any pictures at the moment but I'll try to get some sometime this week when I have time to do a partial dissassembly.
PS How do I get a Youtube video to show in a post rather than just a link?
Old 12-06-2010, 10:52 PM
TheMachinist's Avatar
Default Re: Barge-Mounted Clamshell Crane
Beautiful work!
I really like the detail with brass components. It sure works smooth and quickly. I'll be looking forward to some close up shots of the drive systems and structure.
Jordy
Old 12-07-2010, 12:07 AM
Yes I like how smooth this works.
Old 12-07-2010, 02:25 AM
Boy, for quick and dirty model, that sure turned out nice, Monighan! I really enjoyed watching the video. Smooth running model and it looks like it's very efficient too. Great work.
Old 12-07-2010, 02:49 AM
That's pretty NIFTY!
I dream that someday I'll have barge dredger too, probably cheat a little & use one of my old excavs.
Let's see your tugboat too. Any video of it on the water?
Old 12-07-2010, 08:01 AM
Cool crane! Looks like a blast to operate.
You could make a dragline bucket for it too.
Old 12-07-2010, 08:31 AM
Very nice model! Like others said, smooth and a very good representation of a clam-machine. I see a lot of them operating along the Ohio in Indiana and Kentucky. Some are barge-mounted, some are pedestal-mounted unloading barges.
Old 12-07-2010, 11:33 AM
lorenzo lorenzo is offline
Really nice machine. Do you have some pics of the drums etc? Ho did your clamshell smoothener work?
Old 12-07-2010, 12:19 PM
Iron Art's Avatar
Iron Art Iron Art is offline
Jared, You have built yourself a great clamshell and crane, Looks like it ought to be out on the Columbia River working on the channel. Look forward to seeing it in person someday as I only live up the road a few miles. Fred
Old 12-07-2010, 08:47 PM
Nice job it looks great and run smooth I could see myself playing in the garage with that for hours.
Old 12-07-2010, 09:20 PM
Brian in PA's Avatar
I'd rather be truckin'
Man is that neat!! you got a lot of work in that piece!
Old 12-08-2010, 09:53 PM
Here it is in all it's spaghettiness sitting on it's unfinished barge.
Machinery deck layout. The lower left servo is boom hoist, center is swing, upper left is digging line, upper right is holding line and the tagline winder is on the far right.
The drums are turned out of acetal rod and the centers are bored out to .25". Then I cut the arms off spare servo horns, turned the hubs down to about .255 and pressed and superglued them in so the drums could be mounted on the servo spline. No problems so far.
Swing gear is done the same way as the drums even though it's aluminum. The swing circle is what I think is called double-row ball bearing. The outer piece has a flange on the inside, sort of a tee in cross section, with a ball race machined into both sides. Then upper and lower plates have matching races machined into them and sandwich the flange. Then screws go up through the lower plate, thread into the upper plate to hold it all together and then stick up about 1/4" so the machinery deck can drop over them and be fastened to the swing circle assembly with nuts. Hopefully that makes sense.
Tagline winder. The spring pulls the lever, lever pulls shaft, shaft spins drum, drum pulls bucket.
Old 12-08-2010, 10:06 PM
Tagline runs through this little block. It ain't much, but I'm kinda proud of how well it works.
Bucket is set up with a four-part line but can be increased to six for digging harder material. This is more of a rehandling clam; I have a round-nose toothed digging bucket in the works.
Old 12-08-2010, 09:34 PM
looks awesome!!
Old 12-08-2010, 10:16 PM
If my math is correct, the servos are theoretically capable of lifting 23 lbs. The drums are about 3/4" in diameter and the servos are supposed to be good for 139 oz-in. I divided 139 by the radius of the drums, .375" which comes out to 370 oz, which is 23.1 lbs. Did I do that right?
Old 12-09-2010, 01:31 AM
Many thx for the pix. Your tagline arangement is very interesting. Did you calculate the force that the spring should have or just did you do it by trial and error.
Old 12-09-2010, 06:12 PM
Trial and error. You can see all the holes I drilled in the lever.
Thanks, td9clyde.
Originally Posted by 9W Monighan View Post
Very nice and simple. I like the tag line set up. On some of the early 1900's machines I've been around: I saw a weight that runs up and down a track on the boom this was on a Erie steam crane. My buddy has a Insley half swing machine he's starting restoration on and it has a pipe with a pully on top where a weight just slides up and down inside the pipe,but that was probably for the trip rope when it has a shovel front mounted.
Thanks. I toyed with both ways a little bit but I couldn't figure out how to make it slide smoothly without pulling too hard and without being too bulky. At this scale friction plays a bigger part than it does on bigger stuff.
Originally Posted by tc1cat View Post
NICE!!! Now you just need to scale it up to 1/16th so you can play with all of the semis We need something like this for bigger scale trucks to use instead of just the elevators and payloaders. 30" in 1/48th is about 90" in 1/16th So about a 8' boom would be fun to watch
Thanks. I've been kicking around a 1/16 scale Bucyrus Erie 22B, but that won't happen for some time yet due to a shortage in the employment department.
Originally Posted by sparkycuda View Post
did you weight the lower pulley crossbar or was it heavy enough by itself?
Thanks, Ken. I had to weight the crossbar a little bit.
the clamshell bucket is beautiful. I once built one for my Manitowoc. I really enjoyed that project.
how did you convert the servo motors to run the winches?
kerst
Thanks, kerst. It was kind of a trip when I got it put together and not only did it look like a real clam, it acted like a real clam. On the servos, there are two ways. I couldn't find the page I used, but this is basically the way I did it, though these aren't the best instructions: http://www.instructables.com/id/How-...or-Continuous/
Or you can do it like this: http://www.seattlerobotics.org/encod...0for%20PWM.htm
I'm not really an electronics guy and I didn't feel comfortable poking around the electronic guts. But this is probably the better way to do it because you don't have to worry about the pot changing position.
Old 12-09-2010, 09:18 PM
W900snowman W900snowman is offline
W900snowman is on a distinguished road
Very impressive I love the video and thanks for posting the pictures. Everyone around here sets the bar pretty high.
Old 12-09-2010, 07:43 AM
td9clyde td9clyde is offline
Dozer Builder
that is one cool drag line works very smoothly i like it keep up the great work
Old 12-09-2010, 08:19 AM
