Old 05-15-2011, 06:14 PM
Default Re: IH5070 Paystar 6X6 now a log truck
Joe ,you got that right I used the tiag to drill the holes in the boom today did you feel the ground shake before lunch well the day turned out well after all
we're swingin
http://www.youtube.com/watch?v=ifRW2nxMsZk
Old 05-15-2011, 07:35 PM
scalelover's Avatar
Looking great, but I'm kind of bummed it says your YouTube video is unavailable. Was looking forward to seeing it in action. Anyway the truck looks awesome keep the updates coming.
--Dan
Old 05-15-2011, 07:48 PM
Dan try it again I hit the wrong thing
Old 05-15-2011, 07:54 PM
Stylin n profilin's Avatar
Stylin n profilin Stylin n profilin is offline
I'm tryin Boss!
Stylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura about
DANG!! as fast as that rotates..Heck with trucking...just toss them logs to the mill
One Bus Stop Short Of The Short Bus...
Old 05-19-2011, 05:35 PM
here's what started a shop rampage the other night almost all done and got distracted and forgot where I was
Yes well this 1 came out better
knuckle and turn motor for the grapple
the grapple frame
thanks for looking
Old 05-19-2011, 07:53 PM
Cool project Steve. Nice work on the boom and knuckle.
Old 05-22-2011, 05:34 PM
thanks Scott
Well another week end shot trying to fix this flippin "JD" mill I took a small brake and worked on the pump just about done I need to make a shaft coupling yet .
the grapple base mounted except for bearing blocks at the base of the motor case ( hence the lip )
thanks for looking
Old 05-23-2011, 09:25 PM
Your makin' some cool parts Steve. Just wish your camera could focus so I could see 'em. LOL.
Keep us posted on the micropump when you get 'er running. Next move for me was going to be trying to gear it down a bit - never got the thing to run low enough amperage one to one. I put mine on the shelf for now but will get back to it some day.
Old 05-23-2011, 09:52 PM
thanks Joe the cam takes a back seat for now my wife does a better job , the problem is to get her to take some time to take the pics for me what RPM motor do you have ? I got a johnson @6600 rpm I'm going to try not much torq though ( I just noticed ) we'll see I'm not sure about being able to run this in ECMT meat on the 11th I got to get on a trlr frame and some other things till a new lathe comes ( well new to me )
Old 05-23-2011, 09:56 PM
Brian in PA's Avatar
I'd rather be truckin'
Lookin good Steve!
Old 05-24-2011, 05:56 PM
Originally Posted by ihbuilder View Post
...what RPM motor do you have ? I got a johnson @6600 rpm I'm going to try not much torq though ( I just noticed ) we'll see
Sounds like I have the same motor. I bought a Johnson 12V 6600RPM motor off ebay and also tried the 12V Johnson motor off my Leimbach pump as a test. They both performed almost identical. Labored real bad and pulled 6 or 7 amps (blew a 5A fuse almost immediately). If I remember correctly these Idex micropumps are moving about 5 times as much fluid as a Leimbach with each revolution so I think problem is too much volume. I was going to try a 4:1 gear reduction as next step.
Old 06-25-2011, 07:59 PM
Joe my pump on the shelf to for a little . it looks out of proportion to the truck so I think I'm going to try to get a micro pump from the Germans for this 1 . I have timing pulleys for 4:1 reduction as a stacked unit I plan to get together for my TD40B and the big mack if the UMS pump will not work for it
thanks Brian
I'm pretty much shelving my projects till I get some customers caught up except for somethings I'll use as a trial run on the JD mill . Like the frame pieces for the pup for this truck .
if it does these right then I'll feel comfortable running drop deck frames .
Old 08-15-2011, 10:47 PM
last set of frames till I get a bunch of wheels out of my way
BTW : these have the ryco suspension built in
I'm trying to get these few frames out of the way before I tie up the mill on the 2nd op for WHEELS
Old 08-15-2011, 11:00 PM
spudd spudd is offline
Sweet lookin stuff!!!!!! Great design on the rails. Can't wait to see it all done
Old 08-16-2011, 01:12 AM
Dreamweaver's Avatar
Weaver Of Dreams
They look NICE Steve.. So do the A/C's. Question, are you drilling and taping the mounting holes in the a/c's?
~Mike~
Old 08-16-2011, 07:09 AM
"are you drilling and taping the mounting holes in the a/c's? "
Yes
thanks guys
Old 08-16-2011, 07:20 AM
sneaky-pete's Avatar
Master A-Modeler
Nice work Steve!
I shall call you...the aluminum whisperer
Troy
Old 08-16-2011, 05:52 PM
Snowman's Avatar
Snowman Snowman is offline
those machined parts look great, really impressive work on the dot bumper, incorporating the mudflap mounts, too cool
Nick
My Peterbilt build thread:
Old 08-16-2011, 09:38 PM
Weaver Of Dreams
Man I can't wait to see this trailer built..
~Mike~
Old 08-20-2011, 09:48 AM
4EX 4EX is offline
4EX is on a distinguished road
great rig
