Old 02-10-2015, 02:41 AM
AWR13 AWR13 is offline
Location: Germany, near Freiburg (in the south at the Swiss border)
AWR13 is on a distinguished road
Default Sound needed
Hello folks,
now i need your help.
For my actual projekt i need a engine sound. It should be used for the Peterbild 351/281. So I need a sound without turbo. It is not necessary that the sound is from this truck, it should only sound similar.
The problem is, that i need a lot of different and good sounds. I need this:
The following soundsections are necessary:
1. Engine start up
2. Engine idel
3. Reeving up the engine
4. Accelerate
5. CONSTANT low speed in 1st gear
6. Further acceleration and switching to second gear
7. CONSTANT low speed in 2nd gear
8. Slow down and stop
9. Engine shut down
Does anyone has someting ? In Germany it is impossible to find someone with such a truck or engine for recordings.
Many Thanks
Andreas
