Old 04-07-2015, 02:59 PM
trucklover trucklover is offline
trucklover is on a distinguished road
Question Better battery than this?
Does anyone know what type of battery this is and if there is a better battery similar to it in size? I would like to replace these. Thanks.
File Type: jpg IMG_0053.jpg (157 Bytes, 83 views)
File Type: jpg IMG_0054.jpg (157 Bytes, 83 views)
Old 04-07-2015, 05:00 PM
Krewmember's Avatar
Default Re: Better battery than this?
I can't see the image.
Old 04-07-2015, 08:31 PM
I am trying to reload the images.
Old 04-07-2015, 09:58 PM
Ok. Let me try this.
Old 04-07-2015, 10:15 PM
Here is another shot. Doesn't remain charged too long. Also the motor that it drives has been lifting the trailer slower and slower.
Old 04-07-2015, 11:11 PM
Krewmember's Avatar
Okay it look's like two 7.2v nimh batterys in parallel, so you could try 2 cell li-po batterys if you have a li-po charger. If I had the batterys dimensions it would help me.
Shawn
Old 04-07-2015, 11:40 PM
Krewmember's Avatar
I google searched and found the dimensions to a battery similar to the ones you have so two of theses http://www.hobbyking.com/hobbyking/s..._2S1P_20C.html should work and it would give you 10000mAhs of capacity .
Shawn
Old 04-08-2015, 08:43 PM
Ok. Thanks. I think I will look into this. It looks like it would fit nicely. Should be a lot more powerful.
