Old 04-09-2015, 10:05 AM
Cat966c Cat966c is offline
Default Custom tires technique question
Hey what's up? I was just thinking about a new technique to make home made tires; what if you took an equal diameter tire, heated it up till it's malleable-not liquified-and re pressed it into a new mold with the desired tread pattern. Would that work, or would heating the tire up de-sulfurize it? I was thinking the rubber would remain the same because it's not liquified, and that is what the heavy equipment tire companies do.
Let me know your opinions, thanks
Old 04-09-2015, 12:29 PM
Finster's Avatar
Finster Finster is offline
Default Re: Custom tires technique question
I'm not sure if the method you describe will work. I think to get an answer you may have to experiment yourself. However, I do know that Tom (modelman) made his own tires for his mining truck.
http://www.rctruckandconstruction.co...read.php?t=486
I also remember (if my memory is correct) a guy on a different board made a Tatra 8x8 and created his own tires by CNC machining aluminum molds and using the rubber they use for retreading tires. Of course now I can't find that link but I'll keep looking. I think both methods are quite impressive and yielded nice results. Hope this helps...
Old 04-09-2015, 12:54 PM
Finster's Avatar
I really hate that you can't go back and edit your own posts after a certain time. I understand the reasoning behind it, but still annoys me. Anyway, I got lucky and found that guys tire making molds thread. I'm assuming you don't speak Polish (like myself) so here it is via. google translate:
http://translate.google.com/translat...98&prev=search
Old 04-09-2015, 04:48 PM
That's awesome, thanks! I love the link, very informative and just what I was looking for! However, I don't want to join another forum and I don't speak polish, but would like to know if the re treaded tire stuff is just old tires, or is it a special material?
Old 04-09-2015, 06:07 PM
Finster's Avatar
I think it's a rubber that they use to do retreads. I believe it's not vulcanized yet but I'm not 100% positive. Just look into retreading, I guess. Sorry I don't know more about it...
Old 04-14-2015, 12:16 PM
Thinking about these; http://www.rc-machines.com/en/model-...helin-335-80r8
Does anyone have better pics of it?
