Old 05-08-2015, 02:29 AM
Default What gives?
Well I was charging some double a batteries for my new Futaba 4YF 2.4 GHz, and I thought everything was fine. It took about 5 hrs to charge, and I put the freshly charged batteries in which are brand new btw, turned on the radio and nothing. So I checked to see if I had them in correctly, and I did. The new batteries are Venom 2400 mah, and they seem to be a little bigger diameter. So I put some good 'ol Ray-O-vac and the radio worked. The only reason I needed them charged was to center my servos on my Grand Hauler. Does any of you have a cause for this? It sure has me puzzled.
Thanks, Big John
Old 05-16-2015, 10:12 PM
Default Re: What gives?
Put a volt meter on each battery to see if they charged or not? Maybe one or more is junk out of the box, or your charger is defective?
Old 05-17-2015, 04:50 PM
Thanks for the advice, but I don't have a volt meter...(I should really get one.) But what I did was put the batteries in my camera and all 4 was good. It still has me puzzled. Like I said they are a little bigger diameter, but all contacts were touching.
Thanks again Lil Giants, Big John
