Old 06-04-2015, 06:48 PM
NORM's Avatar
NORM NORM is offline
NORM is on a distinguished road
Default All in one Lipo Charger
im in the market for an All-in-One Lipo charger. looking for plug n play. hopefully no ext power supply. must be capable of charging a 6400 lipo pack. my current Triton2 only does 5000 max.
suggestions?
all the DEDICATED Members will be there.
the hobbiest formally known as Sweet Pete Wrecker, Founding Member of the East Coast Mini Truckers.
Old 06-04-2015, 07:14 PM
mavrick0 mavrick0 is offline
Default Re: All in one Lipo Charger
The capacity of the battery isn't an issue. If the charger is ending the cycle at 5000mah then just start it up again until it peaks. What you need to worry about is the wattage of the charger. To figure that out it's voltage x current. So in your situation to charger that battery at 1c it's 7.4 x 6.4 which equals 47 watts. So any charger with a wattage of 50 or higher will be good. Now this is assume you are using lipos. But if you want a good little charger with built in power supply look at the Hitec x1. If you want a charger that can do multiple batteries look at the Hitec x4 which is a AC/DC charger with 4 charging bays.
Old 06-04-2015, 08:31 PM
this I s the one I bought so far so good
Dynamite DYnC2020 Prophet Sport Duo / Dual AC Lipo / Nimh
Old 06-07-2015, 08:45 PM
NORM's Avatar
Thank you
