Trade ONLY! Swap unwanted junk or swap it for someone else's. |
Like the title says. I'm looking for Globe Liner rails & Driveshaft. One KH rail as a slight bend but everything mounts up still perfectly fine.
Here's a picture of the rails still being used. The bend is right by the back screw hole for the tank. I can take a closer pic it later when i get home from work. Right now theres nothing on the rails but the braces, but I'm keeping those. You'll just get the Driveshaft and rails. ![]()
Not trolling anymore... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Kausekaos; 10-22-2015 at 10:20 AM. |
Not trolling anymore... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
![]() ![]() I'll even supply the 2 needed chassis braces because if I'm not mistaken the Globe Rails only requires one.
Not trolling anymore... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Kausekaos; 10-22-2015 at 08:44 PM. |
Please Delete
