Old 11-20-2015, 04:57 PM
Kausekaos Kausekaos is offline
Kausekaos is on a distinguished road
Default Hydraulic Guide?
I searched on here and couldn't find one. Is there one I missed? Was just curious about the Do's and Donts to hydraulics. ie Using, not using, letting it sit idle etc etc. I saw the sticky to changing the fluid but that's about it.
Not trolling anymore...
Old 11-20-2015, 05:19 PM
Default Re: Hydraulic Guide?
I ask because I wouldn't be able to use it all the time and I wasn't sure if it sat in between use would things get messed up.
Old 11-20-2015, 06:53 PM
When not in use, keep it out of the sunlight in a cool dark place so the hydraulic hoses don't dry out & crack.
If you got to do any wrenching on the model & need to break any hyd connections, clean it spotless!!! Any grime, use an electrical cleaner, pressurized air, Q-tips. The slightest spec of dirt will screw up a valve, plug a fitting.
Old 11-20-2015, 07:20 PM
joe has been digging for years. listen to him
Old 11-21-2015, 05:38 PM
Yeah I'm subbed to his channel lol
Old 11-21-2015, 07:05 PM
Personally I have never had any issues & some models are getting close to 15yrs old. Some that haven't been turned on for a couple yrs, I've just plugged a batt in & go... my basement remains at constant temp year round in the low 60's.
Old 11-21-2015, 08:28 PM
That's what i needed to hear. Was worried about it sitting for a while and me having problems whenever I turned it on.
Old 01-08-2016, 07:20 PM
you should find the volume of fluid that will be in the system, then find the right sized tank. If you don`t the fluid will get hot and damage the pump, etc..
