Old 11-22-2015, 09:57 PM
DADSGARAGE's Avatar
Default PC1800 Front Shovel (1/12)
Started building the PC1800 with a plywood profile the same way that I started the D11 and 777 build. I will be using the original tracks I had on the dozer but will need to add 10 more links and pads, keep in mind I'm not building a true scale model of the shovel but will try to keep it much the same as full scale.
I have made some progress already with this build and will upload more pics and info in time.
Old 11-22-2015, 10:24 PM
DADSGARAGE's Avatar
Default Re: PC1800 Front Shovel (1/12)
Swing bearing build using 200 - 1/4" steel balls and when completed is about 9.375 in dia.
I will be using a sprocket and chain for the swing , this will allow me to put the swing drive motor in under the cab or in a spot that is not needed for something else.
Still need to install the top and bottom seals on the bearing as well as the spacer to get the proper height. Hope this all works...LOL
Old 11-22-2015, 10:56 PM
DADSGARAGE's Avatar
I will be trying these air cylinders on the shovel not sure how well they are made but I'm going to find out. The main boom cylinders are 1.25" ID and the rest are 1.0625" ID. Hopefully the 5/32" tubing will have enough flow.... I'm going to find that out as well.
I also plan on using a full scale valve body and pump , I will need to change the operating pressure in the valve down to 200-250 psi and the pump will need to turn at about 1500 RPM to supply enough volume for the cylinders, not sure if I can get this all to work as I would like but it's worth a try...the other challenge will be getting it all to fit in the model....time will tell.
Old 11-22-2015, 11:54 PM
Princess Auto strikes again!lol I'm liking what you're up too! I think one of the other guys on here used some valves like that in a couple of excavators and they worked alright. What is the plan to spin that pump with? 3408?lol
http://rctruckandconstruction.com/sh...ighlight=pc650
Old 11-23-2015, 07:52 AM
Nice work on the slew ring
Old 11-23-2015, 09:55 AM
Since I'm a Komatsu guy, I've been waiting for this build to start. Great work on the swing bearing! Don't know if it will be a problem, but sometimes when a main relief valve is adjusted well-below its normal operating pressure, it is not very consistent or accurate. I'm guessing this system has an original pressure of 2500-3000 PSI, dropping to 250 PSI might be a problem. Hope it is not for you. Should you need additional technical information about the full-size PC1800, let me know. Be glad to assist.
Old 11-24-2015, 12:07 AM
DADSGARAGE's Avatar
Thanks.......it looks simple enough but was tricky to make....my first mistake was using a three jaw to turn it , should have use a four jaw but got lazy and didn't change chucks and started to get some vibrations in the cuts near the finished size, sometime short cuts aren't short cuts at all.....just end up spending more time trying to fix thing.
Old 11-23-2015, 11:55 PM
DADSGARAGE's Avatar
Yes good ol princess auto...lol...the valve body and pump are from them (got them on sale too heehee) the cylinders are from Automation Direct. Not sure yet what motor will be used on the pump yet, need to turn it at 1500rpm to get the flow needed but I don't actual know how strong the motor needs to be, if I put in a motor that is to big it will just eat battery power. Still need to try runs some tests with pump RPM and see what flow rate is like, going to just use a cordless drill to do the tests on the pump three speed drill will give me some ranges to play with. You would need two 3408 engines to run the full scale shovel.....even then two kitties might not be enough....lol
Old 11-23-2015, 04:12 PM
I am also glad to see this build start. I am not a hydraulics guy but I will follow this all the way. Nice work so far. Post lots of pictures.
Old 11-24-2015, 12:36 AM
DADSGARAGE's Avatar
I'm glad to see this build start too.....lol......I'm with you on not being a hydraulics guy either so this means we can learn together, this is the first time for me making something like this with hydraulics so I do have some learning to do!!! It will be interesting using things that aren't really designed for what I want them to do.....should be fun LOL
I will try post lots of pics.....did I post enough pics of the 777 build?? I always think people don't want to see every little step in the build....if there is something you want to see more pics of just let me know, be glad to post them for you, I usually take to many pics anyway....
Old 11-24-2015, 12:45 AM
We want to see every step! This place hasn't had enough scratch build pictures lately! Cooper can't carry the whole site on his own.lol
Old 11-24-2015, 11:53 AM
I agree with RCP-I want to see everything!! A scratch build and a front shovel. It just doesn't get any better than that for me. I prefer the older cable shovels but I guess they are on the way out. Hydraulic machines take a lot more maintenance and do not last half as long but I understand that is what the companies want today.
Old 11-24-2015, 06:29 PM
RCKiwi RCKiwi is offline
All what those guys said...^^^^^^^^^. Cracking work on the swing bearing too...
Old 11-24-2015, 07:46 PM
Wow, great work on the swing bearing!! I've tossed around the idea of making bearings. Can never find the right size and if I do it's $$$!!! Yup, keep the pictures coming, I usually post pics because I need a break or because something just isn't working out and it's just enough to walk away and regroup. Speaking of that, how is that motor gearbox holding up on the haul truck? This front shovel is going to be a big boy!! Any guess as to how much it may weigh when done??
Old 11-24-2015, 11:12 PM
DADSGARAGE's Avatar
Thanks....I was originally going to buy some big tapered roller bearings for the swing bearing and like you changed my mind after finding out the price, so desided to try build a bearing (was most likely cheaper to buy the bearings if a person considers all the time spent in making it...lol) one thing I like about it is it will transfer the load over a big area unlike some of the models using a small bearing. This model will be heavy and if I did the math right should be able to lift between 80-100lbs or I could just be fooling myself into believing that!
The banebots motor gear box has held in there so far, have stretched the#25 chain and have needed to tighten it a few times but the motor hasn't given any troubles yet...knock on wood...you know how that works...watch the next time I use it something will pile up I want to tear it apart and look at the gears and see if there is any possible failure about to happen, or at the very least clean it and apply new grease....pulling the motor out of that truck is not much fun so I think that's why I haven't yet
Not sure how heavy it will be, if I had to guess I would say it will be in the 140-160lbs range but I could be completely out to lunch on that guess, may even end up being heavier...lol...knowing the size of it and the way I build stuff it will most likely end up being 200lbs HEEHEE
Old 11-26-2015, 02:47 PM
BIG ROLLER BIG ROLLER is offline
BIG ROLLER is on a distinguished road
hello
very good job
like other projects , truck and bulldozer
I want to see the excavator to work
good luck
Old 11-26-2015, 10:27 PM
DADSGARAGE's Avatar
Finished putting the swing bearing together c/w seals and spacers, needed to add spacers to bring the overall height up to what was needed, I didn't have thick enough material to make the bearing tall enough to start with so it will be 4 pcs total instead of two.The total height of bearing c/w spacer is just over 2".
Thats all for now......KP
Old 11-27-2015, 03:33 AM
Rimrock Rimrock is offline
Great project, thanks for posting) When able to scratch build a fantastic swivel bearing like that, I was betting you also would be building scale replicas of the original cylinders But hey, if there is already some stuff out there on can get hold of that is about the correct size and can take the pressure, one can save time naturally.
Old 12-01-2015, 09:49 PM
DADSGARAGE's Avatar
Thanks!! Decided to try use some off the shelf air cylinders that are close to the needed sizes instead of building them, time will tell how well they will work and or for how long...lol
Old 12-01-2015, 10:55 PM
DADSGARAGE's Avatar
I have a question or two for all you hydraulic fellas on here.....
What type of oil filters are being used in models , are there inline and intank
filters??
How much would these small filters effect the flow if the needed volume is greater than the typical RC system??
How big should the tank be in regards to the total volume of oil in the system, should the tank hold the same amount or more, or can it be less providing the oil temp doesn't get to hot? I can't see the temp of the oil in this model being a problem....there will be about 700cc in the system not including what will end up being in the tank, which is one more thing that still needs to be built. I would think that the longer the model is being used the warmer the oil will get....how warm does the hyd. oil typically get in your machines??
I have limited knowledge in regards to hydraulics and no experience with RC hydraulics...zero...so be patient with me as I hope to learn more from all of you and of coarse the good ole " school of hard knocks"
