Old 11-24-2015, 10:12 PM
Default brass tube
How can i bend 1/8 (3mm) brass tube without putting a kink in it?
Old 11-25-2015, 03:23 AM
crisis time's Avatar
Default Re: brass tube
I have had luck bending tube by filling it with dry sand
Just cap one end fill with DRY sand and tap it to compact the sand
cap the open end and bend slowly
Old 11-25-2015, 03:35 AM
Cossett's Avatar
Cossett Cossett is offline
On Leave
I've heard of people filling it with water and freezing it then bending the tubing
Cheers Tracy
Love my Kenworths
Old 11-25-2015, 08:27 AM
What radius are you trying to bend?
Old 11-25-2015, 04:05 PM
Its going to be pretty tight, like a half inch and it will run parellel with itself
Old 11-25-2015, 04:24 PM
If you use sand make it wet and fill the tube. There are spring type tube bender that I have good luck with and also bender fro DU BRO that work good. Ed
Old 11-25-2015, 04:32 PM
ple Search
Search for:
tube benders
SEARCH
Search Results
Searching for: tube and benders
Show All Product Results (174)
Show All Category Results (44)
Category Results (44 found , top 5 displayed)
Show All Category Results >
AIRCRAFTFUEL ACCESSORIES 72 Products
AIRCRAFTLARGE/GIANT SCALE ACCESSORIES 53 Products
AIRCRAFT1/4 SCALE AIRCRAFT ACCESSORIES 50 Products
AIRCRAFTIMAAC ACCESSORIES 50 Products
AIRCRAFTARF ACCESSORIES 36 Products
Product Results (174 found , top 25 displayed)
Show All Product Results >
Sort by:
Filter by Price:
5/32 Tubing Bender#786
Designed for use with 5/32 brass fuel tubing or aluminum tubing, these tools are perfect for most configurations. Does not collapse tubing wall. Perfect for use on air lines for retracts. Bends annealed brass aluminum tubing.
See RC Car Action Editor Matt Higgens review the benders. Click Here
USD$ 16.21
VIEW DETAILS
1/8 Tubing Bender#785
Designed for use with 1/8 brass fuel tubing or aluminum tubing, these tools are perfect for most configurations. Does not collapse tubing wall. Perfect for use on air lines for retracts. Bends annealed brass or aluminum tubing.
USD$ 12.46
VIEW DETAILS
E/Z Bender Wire Forming Tool#480
A commercial quality wire bender, built specifically for the hobby industry. This will bend wire from 0-90 degrees and makes perfect Z-Bends, L-Bends, landing gear & more!
With one movement, the E/Z Bender will form wires to your exact specifications. The E/Z Bender features hardened steel forming dies for long lasting operation. It's design was made to be a perfect addition to the modelers workshop. It can be hand held or easily mounted to your work bench. It also fits perfectly in your bench vise. 1/pkg
The E/Z Bender can be used with spring and music wire up to .047 (1.18mm) and comes with two forming dies for bending the following wire sizes:
Forming Die #1: .015-.020 (0.38mm-0.51mm)
Forming Die #2: .031-.047 (0.79mm-1.19mm)
Now Available: E/Z Bender #2 (#481) for .062" - .093" Wire!
USD$ 27.51
VIEW DETAILS
E/Z Bender Wire Forming Tool #2#481
A commercial quality wire bender, built specifically for the hobby industry. This will bend wire from 0-90 degrees and makes perfect Z-Bends, L-Bends & more!
With one movement, the E/Z Bender #2 will form wires to your exact specifications. The E/Z Bender features hardened steel forming dies for long lasting operation. It's design was made to be a perfect addition to the modelers workshop. It can be hand held or easily mounted to your work bench. It also fits perfectly in your bench vise. 1/pkg
The E/Z Bender can be used on pushrods up to .093 (2.35mm) and comes with two forming dies for bending the following wire sizes:
Forming Die #1: .062-.072 (1.45mm-1.82mm)
Forming Die #2: .072-.093 (1.82mm-2.40mm)
Note: Do not attempt to bend hardened wire (music wire) with this tool.
USD$ 27.51
VIEW DETAILS
E/Z Bender Forming Die (For wire .072" - .093") (1/PKG)#486
USD$ 10.97
VIEW DETAILS
E/Z Bender Forming Die (For wire .062" - .072") (1/PKG)#485
USD$ 10.97
VIEW DETAILS
E/Z Bender Forming Die (For wire .031" - .047") (1/PKG)#484
USD$ 10.97
VIEW DETAILS
E/Z Bender Forming Die (For wire .015" - .020") (1/PKG)#483
USD$ 10.97
VIEW DETAILS
Large Tygon Gasoline Tubing#506
For Gasoline or Diesel Fuel ONLY. This tubing won't harden or crack and remains flexible. 30 feet of tubing.
USD$ 54.14
VIEW DETAILS
Devcon Dev-Tube - Net Wt. 1 Oz. Tube#S-208
USD$ 6.40
VIEW DETAILS
Antenna Tube Assortment (1set/pkg.)#2341
No matter what level of R/C driver you are, chances are, at sometime, you will break your antenna tube on a roll-over. Our replacement tubes are what you need. They are available in 6 different colors so you can match your body color. We also have the caps and tubing to hold everything in place.
USD$ 6.73
VIEW DETAILS
Antenna Tube w/ Cap (Black) (1/pkg.)#2340
USD$ 1.22
VIEW DETAILS
Antenna Tube w/ Cap (Blue) (1/pkg.)#2339
USD$ 1.22
VIEW DETAILS
Antenna Tube w/ Cap (Red) (1/pkg.)#2338
USD$ 1.22
VIEW DETAILS
Antenna Tube w/ Cap (Yellow) (1/pkg.)#2337
USD$ 1.22
VIEW DETAILS
Antenna Tube w/ Cap (Purple) (1/pkg.)#2336
USD$ 1.22
VIEW DETAILS
Antenna Tube w/ Cap (White) (1/pkg.)#2335
USD$ 1.22
VIEW DETAILS
50 ft. Medium Tygon Gasoline Tubing#505
For Gasoline or Diesel Fuel ONLY. This tubing won't harden or crack and remains flexible. Inner Diameter: 3/32".
USD$ 80.87
VIEW DETAILS
Devcon Duco Cement - 1 Oz. Tube#62435
The most popular multi-purpose houshold glue!
Works great on phenolic plastic, glass, metal, wood, crafts, china.
Dries clear.
Dries fast.
Dishwasher safe.
Easy to apply.
Special cap prevents clogging and drying out.
USD$ 3.60
VIEW DETAILS
Devcon Silicone Rubber - 2 Oz. Tube#S-250
USD$ 6.20
VIEW DETAILS
Devcon 5 Min. Epoxy - 1 Oz. Tube#S-205
USD$ 5.45
VIEW DETAILS
3 FT. Silicone Tubing Combo - Medium#892
USD$ 3.58
VIEW DETAILS
Antenna Caps w/ Silicone Tubing (2/pkg.)#2342
Keep your antenna looking neat and out of the way.
USD$ 0.83
VIEW DETAILS
2 FT. Neoprene Fuel Tubing - Medium#225
For Gas, Oil, Diesel, or Glo Fuel. 3/32" ID
USD$ 2.26
VIEW DETAILS
50 ft. Medium Neoprene Fuel Tubing (Black)#199
For gas, oil, diesel, or glo-fuel. Inner Diameter: 3/32"
USD$ 54.68
VIEW DETAILS
Show All Product Results > This is DU BRO site the 1/8 " bender is $ 12.46 hope this helps. Ed
