Old 12-03-2015, 05:12 PM
CustomCrawlerz's Avatar
CustomCrawlerz CustomCrawlerz is offline
CustomCrawlerz is on a distinguished road
Default Custom Bruder Dumper Build
I started this rig a while back now, and have been tinkering on it as time allows. Hopefully I will have the rig run able before the year is out this year. Even if it still isn't finished.
Apparently, I need to upload the pics differently, and link them to here. (Pictures to come soon)
File Type: jpg 20141214_191058.jpg (157 Bytes, 579 views)
File Type: jpg 20141214_191109.jpg (157 Bytes, 579 views)
File Type: jpg 20141214_191130.jpg (157 Bytes, 579 views)
File Type: jpg 20141214_191139.jpg (157 Bytes, 582 views)
Old 12-03-2015, 06:25 PM
Default Re: Custom Bruder Dumper Build
Dump Bed Mounted Box Tipped Up. Cab Sittign in Place on Main Frame
Old 12-03-2015, 06:26 PM
Dump Bed Mounted Box Down, with Cab Sitting in Place
Old 12-03-2015, 06:31 PM
Old 12-03-2015, 06:37 PM
Axles Sitting In Approximate Place Under Main Frame 1
Axles Sitting In Approximate Place Under Main Frame 2
Old 12-03-2015, 06:41 PM
Rear Axle Assembly With Suspension (Top Side View)
Rear Axle Assembly With Suspension (Rear View)
Old 12-04-2015, 08:05 PM
FabOne's Avatar
FabOne FabOne is offline
Looking good! What axles are you using? Can the diffs be locked out? Is that what the larger socket head screw on the upper left rear of the diff housing is for?
-Terry
FabOne
NW Ohio
Old 12-07-2015, 08:56 AM
-Terry
The Axles are from INTEGY. I purchased them a while back for this purpose. They are very nice quality, and constructed of all aluminum besides the Steel internal gears, etc... I do not know if the Difss can be locked out or not, I do not want them locked out myself, or I think I may run into some issues while trying to turn the truck as the wheelbase is so narrow from using the Bruder model. It is about 3-4" shorter then your normal Tamiya tractor. The diffs have oil in them, so that is my thought on why that screw is on the pumpkin of the Axles. Least that's what I used it for, putting oil into the axles.
Old 12-07-2015, 12:25 PM
FabOne's Avatar
THANKS for the info! Yea, after I ask what the screw on the pumpkin was, I remembered that it is for adding the oil.
Nice set-up!!
-Terry
FabOne
NW Ohio
Old 12-31-2015, 05:57 PM
Well, I have had the steering completed and threw a motor on it to be able to run it around. The motor I threw on it will not be the one that I run on it, but I just needed to get a good starting point for starting input RPM for the setup. I have been working on the dump mechanism recently and will post up some pictures and maybe the test speed videos I shot soon.
Old 01-01-2016, 10:37 PM
jeffgp jeffgp is offline
jeffgp is on a distinguished road
i got the same truck . looking to start in the late spring .. what trans is that , looks like it fits well . great start . cant wait to see more progress
Old 01-08-2016, 07:58 PM
This is an E-maxx transmission I have in this truck. It is a 2 speed tranny, and I had a bunch of them laying around when I started the build so it went in.
Old 01-06-2016, 08:51 PM
I Am also going To Modify a Bruder. they are really a good and cheap option. This dump truck looks awesome! Just a question, are you using hydraulics to lift the bed?
Old 01-08-2016, 08:00 PM
No, I will not be using hydraulics to lift the bed. The Cylinder on this truck IS a Pneumatic cylinder, but it is just for the look. The bed will dump as it slides the lower mount for the cylinder along the main frame of the truck. I will post up some pictures of the assembly shortly. It is currently still in progress, but coming along. Slowly.
Old 01-08-2016, 08:06 PM
i found a 3-d print of a drive train for this truck . it should be printed in a week or two . it uses the stock plastic frame and has 4 motors for the rear drive .
Old 01-08-2016, 11:46 PM
Dump Frame Removed
Dump Frame With Added Servo Mount Area
Dump Frame With Dump Drive Sitting In
Dump Frame With Non Driven End Support Built.
Old 01-09-2016, 09:28 AM
So, the Servo will drive the ACME threaded rod, and in turn the nut will move along the shaft. The nut will be tied to the lower mount (1/4" aluminum bar you see opposite where the cylinder mounts) and as the nut moves along so will the bed Dump or lower. I know the speed with the current servo I have in it will be very slow, but if needed I can change out the servo easily in the future. I also am going to be using a Brass round Nut on the ACME rod instead of the standard ACME nut, as that will allow me the wear point instead of the shaft.
Old 01-14-2016, 10:05 PM
Here are the Pictures I took today with the dump drive assembly finished and operating.
Old 07-06-2018, 06:32 PM
Post Re: Custom Bruder Dumper Build
We have had this in process for a long time now. Custom Crawlerz BRUDER MAC GRANITE Dumptruck conversion. Running INTEGY Aluminum axles with steel gears and full ball bearings. 6WD with 2 locked axles, INTEGY Aluminum Rims, INTEGY tires, Full Custom Aluminum Frame, 2 Speed E-Maxx transmission, w/INTEGY 55t Lathe motor. Servo driven Custom dump bed mechanism.
Full LED Lighting system (in the works) with boomerang shaped beacon lighting.
Views of the truck with the box in various positions.
