Old 12-03-2015, 07:12 PM
CustomCrawlerz's Avatar
CustomCrawlerz CustomCrawlerz is offline
CustomCrawlerz is on a distinguished road
Default Custom Front End Loader Build
CAD First Look Front End Loader Main Arm Assembly with Bucket
Old 12-03-2015, 07:16 PM
Default Re: Custom Front End Loader Build
Main Arm Right Side 1.
Main Arms Left/Right Assembled.
Old 12-03-2015, 07:21 PM
Bucket Fabrication 1
Bucket Fabrication 2
Bucket Fabrication 3
Bucket Fabrication 4
Bucket Fabrication 5
Bucket Fabrication 6
Bucket Fabrication 7
Bucket Fabrication 8. With Mounting Tabs
Bucket Fabrication 9. With Mounting Tabs Rear View.
Old 12-03-2015, 07:47 PM
Bucket Dump Arm View 1
Bucket Dump Arm View 2
Old 12-03-2015, 07:51 PM
Assembled Main Arms. Bucket Mounted. Dump Arm Connected 1
Assembled Main Arms. Bucket Mounted. Dump Arm Connected. Operating Height 1
Assembled Main Arms. Bucket Mounted. Dump Arm Connected. Operating Height 2
Assembled Main Arms. Bucket Mounted. Dump Arm Connected. Operating Height 3
Assembled Main Arms. Bucket Mounted. Dump Arm Connected. Operating Height 4. Size Comparison to Tonka OEM Bucket.
Old 12-03-2015, 08:07 PM
Cad .pdf View of the Cutter Bar for the Bucket on the Loader (x3)
Old 12-04-2015, 07:58 PM
FabOne's Avatar
FabOne FabOne is offline
GREAT job!! Keep posting!
-Terry
FabOne
NW Ohio
Old 01-09-2016, 12:23 AM
Quick CAD Draw up of a frame to go with my main bucket assembly. I have made a small change to this already, as I noticed a problem with the bucket all the way down here.
This is a view with the Bucket lifted all the way up and dumping.
Old 01-10-2016, 08:11 PM
is the machine going to be hydraulic?
Old 01-11-2016, 09:37 AM
The initial thought is no, as per cost. But that may change if I can get my hands on a kit for the right price.
Old 01-11-2016, 03:44 PM
if you can afford hydraulics, I would recommend it. Linear actuators are also a good idea. Is the wheel loader going to have a transmission?
Old 01-11-2016, 05:31 PM
I was thinking linear actuators for the arms. I was not planning on running a transmission. I was planning on running 4 planetary Gearmotors. One direct on each wheel. I already have them figured out and they will go inside the axle tubes.
