Old 12-04-2015, 04:31 PM
Default Lipo charging device question
Never seen this device before and wondering if it's safe to use. All my lipos are xt60 plugs and this sure would be handy for charging.
http://www.ebay.ca/itm/Common-Sense-...wAAOSwv0tVYy1a
Old 12-04-2015, 05:25 PM
Default Re: Lipo charging device question
(Be sure to charge only batteries of the same voltage and cell count at the same time (2S with 2S, 3S with 3S, etc.). Connecting batteries of different cell counts to the Paraboard at the same time will result in immediate damage to your batteries and the Paraboard and may result in fire. Charging batteries of different capacities together (for example, one 11.1V 2200mAh battery and one 11.1V 5000mAh battery) is ok, but the voltage of all batteries must be the same)
looks like a fire waiting to happen to me
Old 12-04-2015, 06:08 PM
Prodrvr2006 Prodrvr2006 is offline
Prodrvr2006 is on a distinguished road
If you want to use a paraboard, get the one from Revolectrix...it's a lot safer that that one. http://www.revolectrix.com/MPA_XH.htm
Old 12-04-2015, 08:04 PM
Don,t do it just bite the bulit and buy a multi port charger.
Old 12-04-2015, 11:16 PM
mavrick0 mavrick0 is offline
Also if you don't have a charger that will do 200w or more then it's not worth it.
Old 12-05-2015, 10:20 AM
Thanks everyone. My current charger is only 80watt and Travis made a good point. It's time to get a new, better charger for sure.
Any suggestions on a good quality multi port charger out there?
Old 12-05-2015, 11:33 AM
All depends on your budget and the type of batteries you are charging.
Old 12-05-2015, 12:06 PM
Majority of my batteries that I'd like to multi charge are 2S. 2200ma. And I'm probably going to have to pay atleast 200 for a decent charger?
Old 12-05-2015, 12:25 PM
Easiest one to get a hold of and is ac/dc is the Hitec 4x plus but it's a little higher then your budget: http://www.greathobbies.com/producti...od_id=HIT44167
You can get a hobbyking kind of version but it's dc only so you'd need to get a power supply to use it.
Old 12-05-2015, 12:41 PM
Thanks for the info bud. If you promise me this will be the last charger I'll ever need then it's worth the cash.
I should have been smart instead of cheap when I started in this hobby. This will be my 4th upgrade in battery chargers I've already spent that much on cheaper ones and should have just got one of these in the first place!
Old 12-05-2015, 11:39 PM
Yes get the HiTec it is worth it and I as well as most of the guys I know have one.
Old 12-05-2015, 11:35 PM
I got this exact charger from the bst on this here forum a yr ago... works awesome! Left side of the charger I have programed for 3s & the right side is 4s; and most everyday there's atleast 3 batts being charged simultaneously.
Old 12-05-2015, 02:26 PM
In this hobby I have a few things that I don't cheap out on and one of them is a charger as it's something you don't want to replace that often and the better the charger the better they care for your battery and the longer they will last. I can't promises it'll be your last charger but it will last you a long time.
I could send you a link to my charger but I'm sure that would scare the **** out of you at just the price tag and then you need a highend powersupply to run it.
Old 12-06-2015, 09:55 AM
Yup, what he said. Im a big advocate of high quality charger. From experience
Old 12-06-2015, 10:17 AM
Cellpro powerlab 6 or 8 and the iCharger 4010 duo would be the last chargers you would need. Buy once, cry once and you're done. I went through 4 lipo chargers before biting the bullet on a high dollar system.
Old 12-06-2015, 02:17 PM
Actros4160's Avatar
I got the Hitec 4x plus from Amazon last xmas for about less then $200. Shop around for it.
Old 12-07-2015, 04:43 AM
ddc333 ddc333 is offline
I 2nd the powerlab 6
I cried for a week but I should never need another charger ....
I hope
Daniel
Old 12-07-2015, 05:19 AM
I hope
You shouldn't...even if you were running heli's or boats and you have to charge multiple 6s lipo's quickly. It's the safest, most accurate charger I've ever had. I juice it up with a 24v 1150w power supply.
Old 12-07-2015, 07:54 PM
I looked at the power lab and the parallel adapter. Can the power lab charge more than one battery at a time without the parallel adapter? How do you monitor how much you put in each pack when charging with the parallel adapter? How do the charger and adapter regulate the charging rater of each pack? With NiMh how does it regulate the current to each battery?
Old 12-08-2015, 04:41 AM
Hi Travis
I can't answer those questions as I don't parallel charge, but I will test it out and see how it works.
I found I don't need too as I can charge most batteries in 20mins I have a power supply connected to it as well
http://www.revolectrix.com/support_docs/item_1380.pdf
have a look at that it may answer some of your questions
Daniel
