Old 12-13-2015, 09:43 PM
Cat966c Cat966c is offline
Default 966 update
So I'm going to try to post pics of my update for the first time in months, so here goes nothing
File Type: jpg image.jpg (157 Bytes, 473 views)
Old 12-13-2015, 09:50 PM
Default Re: 966 update
Another
File Type: jpg image.jpg (157 Bytes, 471 views)
Old 12-13-2015, 09:53 PM
Is it working???
Old 12-13-2015, 10:10 PM
nope
if using photobucket click on the img link copy then paste here
Old 12-13-2015, 10:42 PM
I'm not ): I was using the upload from computer thing.
Old 12-14-2015, 02:18 AM
Northern Farmer's Avatar
Upload pictures to www.tinypic.com and post them like this [img]....[/img]
Old 12-14-2015, 12:42 PM
Here's some of the first and progressing from there
[/IMG]
Old 12-14-2015, 12:44 PM
http://i65.tinypic.com/idcb9l.jpg
Old 12-14-2015, 12:46 PM
<a href="http://tinypic.com?ref=idcb9l" target="_blank"><img src="http://i65.tinypic.com/idcb9l.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Old 12-14-2015, 01:09 PM
Look how sh*t welds are lol ):
And one with the metal arms (they were too long, so I had to shorten them and instead of grinding them down, I cut and had to crappy tac weld them
With shorter arms
Aaannnnnd where we are now
Actual machine:
Old 12-16-2015, 11:56 AM
Thanks for the tip northern farmer!!!
Old 12-16-2015, 01:08 PM
Are you using a MIG welder? Is it flux core wire or using Blueshield gas? I'm not a welder but it looks like you need more heat.
I like the build! Keep the pictures coming!
Old 12-16-2015, 03:53 PM
Yeah, I'm using the mig I mentioned a while back. And the wire is .032 regular argon sheilded.
Old 01-10-2016, 12:51 PM
CustomCrawlerz's Avatar
CustomCrawlerz CustomCrawlerz is offline
CustomCrawlerz is on a distinguished road
Well, It def. needs something. More Heat; Closer to material; Hoping the welds stay together for you when you start using it.
I think when I build my loader, I will be using all Aluminum plate for the frame and such.
Keep up the progress.
Old 01-13-2016, 02:47 PM
Thanks. I haven't worked on it for a while lol. I'm being lazy because the cross tube is frustrating. ):
And about the welds: yeah that's what I was afraid of, but shouldn't I be able to weld over the crap welds or grind them off and do better ones?
Old 01-13-2016, 02:50 PM
Also; I know these are crap weld (for the most part) lol. This model is basically for me to look at and maybe sometimes play with.
Old 01-13-2016, 03:27 PM
Your wire size is quite large for the thickness of material you are working with. I would try .025 if you can. You may have to change the drive wheels on your welder to run that though I'm not sure. I am using .035 wire in my MIG and it is very difficult to weld thin material without it looking like bird turds.
Old 01-13-2016, 03:57 PM
Welds don't need to look their best. The welding you have done looks way better than the welding on some homemade or customized machines. I like the machine a lot. There aren't a lot of historical RC construction vehicles out their.
Old 05-19-2016, 03:09 PM
Well it's been a while but (as most of you know, cosworth and rcp lol) I am getting near the electronics (and final) phase of the build! So I thought I might share some progress pics:
Old 05-20-2016, 07:08 AM
.032 is OK , but slow the wire feed down turn the shielding gas up ( if that is what your using. If flux core wire, clean your metal better.) a little more heat wouldn't hurt .
