Old 12-28-2015, 09:43 PM
avel avel is offline
Default King Hauler driveshaft length?
I'm sitting here in my truck wanting to purchase a driveshaft from RC4WD but I don't know which one to get. All I know is I need one that will fit over the 5mm output shaft. I'm thinking the 5.7" - 7" one will work, but I'm not sure.
So anyone know the right one to buy, or the length of the stock driveshaft?
My stock one slips/jams up at times because I took off the "shocks" on my drives for more articulation.
Youtube username iamaman27
Old 12-28-2015, 10:00 PM
Default Re: King Hauler driveshaft length?
Check out this thread for an inexpensive way of making your own shafts.
http://www.rctruckandconstruction.co...read.php?t=708
You can also adjust the drive cups on the axle and transmission so there is very little fore/aft play in the shaft when all tires are flat on the bench, then see what you get when you flex the suspension and readjust accordingly.
Old 12-28-2015, 10:02 PM
yeah i've already read that thread a couple days ago. Pretty cool.
Also good idea with adjusting the cups, I hadn't thought of that.
I mainly want to buy something so when I get hometime I can pop it in, and go play
Old 12-29-2015, 05:25 AM
Kingcam2's Avatar
Kingcam2 Kingcam2 is offline
HI Avel
These are the ones I am using in my King Hauler,
http://www.integy.com/st_prod.html?p...w#.VoJe7hV96Uk
http://www.integy.com/st_prod.html?p...w#.VoJe-RV96Uk
but they are out of stock of them at the moment.
Regards Cam.
Old 12-29-2015, 03:55 PM
Thank you very much for that information.
Old 01-01-2016, 06:10 PM
Sped74's Avatar
Sped74 Sped74 is offline
Sped74 is on a distinguished road
Thanks for posting about the custom driveshaft they are awesome
